remove front speakers, install amp - 1984 190E
how do i remove the front speakers from my 1984 190E?
and another question.. does anybody know forsure which wires are ground, power, etc on the stock becker radio.
and a third question: what is the easiest way to get a power cable (for an amp) from the engine bay to the boot/under the backseat.
cheers, any help would be useful.
86 190E 2.3-16, 85 190E 2.3-16, E320
Two screws on the grille cover, then grille will pop up. Pull it forward and up to remove.
Wiring is:
Memory (+12v Constant) Red
Ignition (+12v Switched) Black/Yellow
Ground (-) Brown
Illumination Gray/Blue
Dimmer (none)
Power Antenna Blue
S p e a k e r s
Right Front (+) Black/Green
Right Front (-) Black
Left Front (+) Black/Red
Left Front (-) Black
Right Rear (+) Black/Green
Right Rear (-) Black
Left Rear (+) Black/Red
Left Rear (-) Black
Run power down the passenger side. If you pull the backseat you will see some grommets leading to the trunk (boot).
Wiring is:
Ground (-) Brown
Dimmer (none)
Power Antenna Blue
S p e a k e r s
Left Rear (-) Black
wait.... the brown wire is the ground for the becker radio? i remember seeing a wire not connected to anything an i think it was the brown one... would this explain why the radio suddenly cuts out and switches itself on and off repeatedly at high volumes and occasionaly when the lights are on?
well thanks anyway, the power cables are all i really need as i am rewiring all the speaker cables, and i will find a new ground. thankyou for your help.
as to the front speakers... i can get the grills off fine, thats the easy part... but i cant get the speakers out of the holes. iv tried to lever them out with a knife or screwdriver but i cant get metal, i just get the cardboard like surround . i hope i dont have to take the dash apart...
They should pop out. The years make them stick a bit, but they aren't screwed in and taking the dash out is overkill. Keep prying with a flat tip screwdriver, they will pop out...
![Talking](https://mbworld.org/forums/images/icons/icon10.gif)
thanks every body... head unit installed... tempory at the moment.... will redo with heatshriinks tomorrow after work.
passenger side speaker installed... turns out they have clips holding them inplace... drivers side still a bit stiff.
amp and subs waiting to be picked up from shop.
1986 Mercedes Benz 190E 2.3
cool
i ordered speakers for front and rear, they arrive tomorrow, panasonic 2-way 4 inchers all around, i'll put in an HD receiver in a few weeks, after i get a job.
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
Euro 1985 190e 2.3-16vlv
Just for ****s and giggles, you should take a few minutes and read through these two threads.
Adding An After Market Radio
How To Route Your Sub Wiring
Enjoy.
Enjoy.
I was thinking of having Circuit City install the radio, the rear speakers went in ok, the fronts didn't fit, sold them in a day for cost on Craigslist. MB is as bad as Dell with their proprietary equipment/parts ![crazy](https://mbworld.org/forums/images/smilies/crazy.gif)
My sunroof switch went out a few weeks ago, the clown selling me the car said the motor was going, it was actually the switch going out. I had to use the spark plug wrench and the little thing in the trunk to close the damned thing. Got a new switch and everything is hunky dory.
I just hate that Becker!!!!
![Violent](https://mbworld.org/forums/images/smilies/violent.gif)
Maybe I'll get it from Crutchfield instead, they are good about giving free connectors/wiring harnesses for their radios. I'm used to simple cars, had a Geo Metro with power nothing the last 9 years. Now I have an over-engineered, power-everything Benz
![Cheers](https://mbworld.org/forums/images/smilies/cheers.gif)
