190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
Lowering my 190e 1990
Old May 1, 2007 | 05:31 PM
XXX's Avatar
XXX
190e 2.0L 1990 w201
I have not done much work on cars before, but i am not afraid to try. I was planing to lower my MB, i have gas dempers. How can i do this? Do i need to buy new dempers or can i modify those i have? If i need new dempers what type do i need? I am waiting for new rims that will be 17" with tires 215/40 ( http://www.alcar.de/563_DE.0?webdid=...vid=4&webbid=0 ) They are starting to make them in mid May . I think the MB now is to high and it looks funny, so therfore i want to get it a bit lower. Anyone that can give me some tips or help here?
Old May 1, 2007 | 06:05 PM
MTI's Avatar
MTI
'85 190E 2.3-16 '99 C280 '11 GLK350
Changing the ride height on the W201 is done exclusively via the coil springs and to a lesser extent, the spring pads located at the top of the coils. The struts and shocks do not affect ride height, however "sport" struts and shocks should be used when using lowering springs.
I would suggest getting your new wheels and tires fitted before lowering, so that you can "fine tune" the final settings with thinner spring pads, provided that the ones you currently have aren't the smallest/thinnest.
Old May 20, 2007 | 11:41 PM
saabfan's Avatar
1987 16v
i have removed the air leveling system from mine and run h&r springs with 205/50/16
Old May 21, 2007 | 05:48 AM
Kynyption's Avatar
Euro 1985 190e 2.3-16vlv
You had bags on your car?
Kewll./.
