190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
Oil Oil
Old Jan 29, 2008 | 02:08 AM
tunayballa's Avatar
1989 W201 1999 W210
Oil Oil
What brand/type of oil does everyone use?
Old Jan 29, 2008 | 10:48 AM
PhilipM1's Avatar
1993 190E 2.6
93 2.6 engine.
Kendall synthetic blend. Gets changed every 3k miles or one month. depending on when I have time to get it in there.
Old Jan 29, 2008 | 11:45 PM
tanktube67's Avatar
2008 Black Out C350 Saks Edition / 87 VW GTI
mobil synt
Old Jan 30, 2008 | 12:26 AM
Wolf190's Avatar
1989 190E 3.0L 5speed
If you ask me synthetic oil is no good for old cars, only new ones. Mine is a 1989 and I use conventional 20w 50. Conventional just has more minerals or something in it that the older engines are designed to have present, go to synthetic and it may or may not have an effect on your car in the long run.
Old Feb 3, 2008 | 01:00 AM
itz16v's Avatar
89 300ce//// 86 190e 2.3-16v//// 12 CLS63
I use Mobil 10w40 every 3000k miles, I've been using this oil for the last year's.
Old Feb 16, 2008 | 12:25 PM
tanktube67's Avatar
synt oil works great on old cars
Old Feb 26, 2008 | 01:39 PM
PhilipM1's Avatar
1993 190E 2.6
Anyone use that oil that is suposed to be "elastic" where it rebonds with the closest oil providing continued lubrication or something better then reuglar oil. I forgot who makes it. Penzoil or GTX I think.
Old Feb 26, 2008 | 02:38 PM
Untertürkheim's Avatar
#1 If you ask me synthetic oil is no good for old cars, only new ones. Conventional just has more minerals or something in it that the older engines are designed to have present,
#2go to synthetic and it may or may not have an effect on your car in the long run.
#1 Not true. The only cases where this applies are the Low SAPS oils designed to meet MB Spec 229.51. There are so few of these oils anyway, and they are nearly impossible to find.
#2 It will have affect your engine, it will run better (smoother and more efficient) in the short run, and last longer in the long run.
Old Mar 2, 2008 | 02:49 AM
Gullwing's Avatar
1987 190E 2.3
It may cause a few oil leaks. After I switched to Mobil 1, the rear main started leaking. It is not real bad, but one of these days I will get around to replacing it, but then I have said that for almost three years.
