190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
Green filter
Old Feb 28, 2008 | 06:46 PM
PhilipM1's Avatar
1993 190E 2.6
Green filter
Where do I get one? I currently have a K&N but its filthy, so im replacing it. If green filters cost just as much I might try those instead.
Does anyone know wich is better from personal use in a 190. I read all about the pro's and cons to each one. but has anyone ran a K&N and then whent to Greens andnoticed a differecne?
Old Feb 29, 2008 | 12:03 PM
MTI's Avatar
MTI
'85 190E 2.3-16 '99 C280 '11 GLK350
Honestly, anyone that is able to actually "feel" a change in performance in air filters . . . should be applying and lending their extraordinary talent to some higher good.
The typical scenario is that a new filter may result in some change over a dirty or clogged one. The true test would be "new versus new".
Then there's the "placebo effect" and the necessary calibration of the "seat of the pants dynometer"
Old Feb 29, 2008 | 01:18 PM
PhilipM1's Avatar
1993 190E 2.6
I found their website. They dont make a filter for MB in 93 lol.
Old Feb 29, 2008 | 05:26 PM
ohlord's Avatar
Stick
in a new oem filter for 14 bucks from
http://www.autohausaz.com/search/pro...2@Air%20Filter
It will out flow any kn or green and you will always have a nice clean filter if done yearly.
ohlord
Old Mar 1, 2008 | 10:16 AM
PhilipM1's Avatar
1993 190E 2.6
ohlord
Are you telling me that a stock filter will have the same airflow and performance as gas saving as a K&N? When I put my K&N in, I actually notice a difference in the higher RPM, 4K and up, and I get 26mpg wich is better then most of the people on here from the polls I have seen. And those MPG's are driving as fast as I do. So I find it hard to believe that I will get those same numbers from the stock filter most of you probably have. But, im open to the idea with anyone agree's ill get the same result im looking for.
I also drive 40k miles a year so instead of buy 3 stock filters a year, I just buy one K&N. It end up being about the same price since I can get stock filters here for about 20 bucks. But I get the MPG bennifit, wich when you drive 40k miles ayear is important.
Old Mar 1, 2008 | 11:13 AM
ohlord's Avatar
How
many miles do you have on the 190e today?
Yes I am telling you the oem filter flows all the air that little engine needs.
Ever have problems with off idle acceleration?
How much does the cleaning and oil kit cost you doing it 4 times a year,properly?
25 highway is about par for the course on the 2.6 and if you are driving 800 miles a week it must be all highway driving and that is why you show better mpg than the polls
ohlord
and since you are the OP on this thread please tell me how filthy the k/n filter is if you clean it properly all the time?And how is it flowing more air than a oem filter for 14 bucks?
Old Mar 1, 2008 | 12:16 PM
PhilipM1's Avatar
1993 190E 2.6
ohlord
I currently have 210k. I drive mostly city actually. There is only one highway I drive on (mostly) and its only 8 miles long. Its a bridge that connect Clearwater and Tampa. I do a lot of driving. My K&N is nasty right now so im replacing. I dont clean it ever. I just buy a new one once it gets gross. I dont want to over oil it and screw up the 400$ MAF. Ide rather spend the extra money on a new filter.
To me, it just seems like a higher airflow filter, with better filtration, is the way to go. My car see's 100mph+ at least once a week. I usually drive and shift between 3k-4k. Its an auto but I can make it shift where I want. It also see's the mechanic once a month for oil changes and gets looked over for preventive maintnce. Ive only had the car 2 years in may coming up. I have about 60k miles put on it. But I also stopped driving it for 2 1/2 months when the rad needed to be replaces because I broke off the plastic piece doing the upper hose. That was a costly mistake.
whats Off idle acceleration? Accelerating from a standstill? When im sitting and I hit it, there is a short half second delay, but I thought that was because its all mechanical and my car idles at like 550 wich is low.
Old Mar 1, 2008 | 12:37 PM
ohlord's Avatar
So you
actually did about 23,000 miles last year and that would have been 2 brand new no oil free flowing oem paper filters for 14bucks each.
You get your oil and filter changed every two thousand miles?Why not do it yourself an oil filter is only $3.99
Try a clean oem air filter from http://www.autohausaz.com/search/pro...2@Air%20Filter
and see if that helps the acceleration lag.
radiator.com has aftermarket oe radiators for about 95 bucks delivered for your model.
Old Mar 1, 2008 | 12:55 PM
PhilipM1's Avatar
1993 190E 2.6
I drive ~3k miles a month. So I get it changed once a month. It only cost me 10$ and I use syth blend. Plus keeping my car at the mechnic once a month keeps my car running is good order. I drift, so I get alignments done fregeuntly, my tires rotated frequently, and rebalanced and all that.
Are you saying a more restrictive air filter will help with my off the line lag? Ill buy the filter just to try it!
I got my radiator for $120. Its the labor I didnt like.
Chain reaction... I replace the top hose, break the radiator plastic piece it goes on, then have to replce the rad, when I do that I dont put the hood lack back on, so I have to break my grill to get the hood ope nto attack the latch properly. Now I dont have a grill. But im thinking about getting the S600 grill off ebay.
Old Mar 1, 2008 | 01:16 PM
ohlord's Avatar
You
are not understanding me
the oem filter is not more restrictive.It flows more air and cleaner air than the k/n.
10 buck oil changes?filter is 4 bucks several qts. of pricey syn blend plus labor and you pay 10 bucks?
Old Mar 1, 2008 | 01:36 PM
MTI's Avatar
MTI
The notion that the stock paper filter is "restrictive" might lead one to believe that every Mercedes engine is starved for air, or not getting the necessary amount of air. Imagine the shock and surprise that would cause in the motor engineering departments of every car maker that doesn't use the K&N filter design.
Choose whatever air filter element you car to use in your own car, but be careful when touting "performance" enhancements without the necessary "before and after" objective testing.
Old Mar 2, 2008 | 02:59 AM
PhilipM1's Avatar
1993 190E 2.6
I get a frequent buyers discount. My best friends dad runs the place. He hooks it up since im in there 3x more then anyone else, since I drive about 3x more then anyone else.
Keep in mind I get an alignment every 2 months. I buy new tires every 4-6 months. Ive had him redo my suspension and some other things. He makes plenty of money off me.
20$. now with the price of oil going up. I use kendall syn blend.
Old Mar 2, 2008 | 03:07 AM
PhilipM1's Avatar
1993 190E 2.6
isnt the main selling point to K&N that you can get MORE air in? Giving better MPG and more "performance" ? Im not saying the stock filter is not designed to a certian spec. to be right for the car. but isnt the car built to a certian standard, and then you add one aftermarket items to change that.
Maybe the way our car is designd it doesnt make much difference, but dont most car get an increase when you put in a K&N or a weapon R intake system? Dont the show gain of +20hp in some vehicles? I know the 190 isnt really one for performance parts (16v not included). Are you guys really telling me im getting nothing extra out of the k&n?
Old Mar 2, 2008 | 06:48 AM
ohlord's Avatar
Yes
That is what we are telling you.
As an example if one of the models that is a performance star with power to spare is limited to a top speed of 155mph by a setting in the cars ecu and by changing that limit the car can do 170mph on a stock paper filter can you see how the oem air filter flowed all the air the engine needed....
do you think with the 2.6liter 190e a paper filter of the same construction and material as the one in a slk55 kompressor has any problem suppling all the air your engine needs?
Old Mar 2, 2008 | 01:45 PM
PhilipM1's Avatar
1993 190E 2.6
Well this conversation has been very educational. Thank you guys.
So my next question is, why do people spend extra money on K&N if it really isnt doing anything extra?
Old Mar 3, 2008 | 04:36 PM
MTI's Avatar
MTI
K&N is a good product and I've used them in the past on cars and motorcycles. The biggest advantage they have is that they can be cleaned and recharged (oiled) so that if you run your vehicles in a dirty/dusty environment, like off road, trail riding or dust storms, you can easily recover the high initial costs of the filter, cleaner and oil compared to buying new filters.
As for "more air" . . . the claims are misleading, since internal combustion engines are pumps. Air is sucked in on one side and pushed out the other and there needs to be a balance of what comes in and what exits the pump.
In our cars, the design of the fuel injection metering system is all done in the Air Fuel Meter piece, unlike the old fashioned carb engines that had down or side draft. The ancient system in our cars doesn't measure air mass, only temperatures, so it won't know if there's more air flowing into the AFM or not.
Why do people buy it? Marketing and the simple desires we have to "gain performance" without really paying the necessary price. In the world of HP gains . . . if it were really easy to get real HP gains, everyone would be doing it.
