190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
Will a W202 Stock Springs fit to a W201?
Old May 13, 2010 | 01:26 AM
kuch326's Avatar
2000 C230 Kompressor, 1999 SLK230 Kompressor
Hi! Can anyone tell me if the stock springs for a W202 will fit a W201? Kindly give in details if it doesn't fit. Thanks!
Old May 15, 2010 | 07:40 AM
kuch326's Avatar
Bump bump
Old May 16, 2010 | 05:11 AM
AMGC's Avatar
Mosselman 190E 16V+ C63S+ Abarth 595
no.
Old May 17, 2010 | 02:37 AM
kuch326's Avatar
Can you tell me why it will not fit? In details if possible. Thanks.
Old May 21, 2010 | 08:19 PM
AMGC's Avatar
different size, spring rates, ect. You can use W124 springs in a 201 though. I have a set of OEM 190E Sporline Limited Edition springs for sale if interested. PM me
Old Jun 17, 2010 | 10:45 AM
jonny terror's Avatar
190 e 2.6
My question is , what size wheel can u use if your going to use aftermarkeet suspension. I want to use a 18 inch, but plan to lower the vehicle
Old Jun 22, 2010 | 11:03 AM
AMGC's Avatar
its all about tire size. I cant fit my foot under either of my 16Vs and ones on 16s and ones on 17s with absolutely no rubbing. You can be pretty slammed on 18s on id say 195/40s
Only problem with 18s is it makes the car itself sit higher off the ground this making the car not look low from the front or rear.
Old Jun 22, 2010 | 11:32 PM
YNVDIZW124's Avatar
lots of cars
You can use w202 springs on a w124, why not a 201? The 190e and the w202 should have similar curb weights.
