190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
190E 2.6 Heat coming from both side vents into Cabin
Old Sep 13, 2010 | 06:31 PM
karora's Avatar
Cool 190E 2.6 Heat coming from both side vents into Cabin
Hello All, I have MB 190E 2.6 1993 model, I am having this problems for few years, both my left and right vents blow heat into the cabin when I am driving. Sometimes, the temprature goes upto over 100F degrees. help
Old Sep 14, 2010 | 02:30 PM
Sincity's Avatar
You have a vacum issue somewhere in the tempmatic system. There is a long thread on the subject on benzworld dot org. There is a heater valve under the leaf screen in the compartment next to the battery. Vacum is lost somewhere and not holding that valve up to cutoff coolant flowing through the heater core. The simple fix is to take the valve off, remove the vacum bellow from the bracket, use a zip tie to lift and block the coolant flap and reconnect. In the winter, reverse procedure so you have heat again. Hard to describe and best that you read the thread.
