190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
1986 190E 2.3 US auto Starter test/removal
Old 07-07-2012, 01:44 PM
6point3's Avatar
1958 MB 300d
Is there enough room to remove the starter out the bottom, or do I need to disconnect tie rods ?
It looks very tight in there.
Also:
the bracket that holds the 'front' of the starter: how many screws/bolts and what size ?, is it easier to remove with the bracket, so where and how is IT attached ?
BTW my 190E is 2.3 4 cylinders, 147K MILES, automatic,1986
Original reason for changing starter: I am told the solenoid is fried (how can you even tell?). the car doesn't make a sound when Ignition lock/switch is turned.
(It's not battery related), but maybe safety neutral switch related: same in neutral, where would I find the SN-switch ?
thanks all
Old 10-23-2012, 02:35 PM
6point3's Avatar
1958 MB 300d
just a quick reply
does anybody work on these cars ?
Quick Reply: 1986 190E 2.3 US auto Starter test/removal
