Reviving my 190e !!!! Any helpful hints?!
BEFORE i do any of that however, I need some valuable advice so that I don't end up paying for random BS because I didn't take precautionary measures. Basically I went to school for 2 years and my sister just seems to have forgotten the 10 times or so I told her to start the car so the car stays good.
its a 1989 190e 2.3 btw
***main question*** here is, what things should i absolutely check? ie.) lubricate, tighten, bleed, flush, or anything along those lines before I attempt to turn over the engine and get it going again? Any help would be MUCH appreciated. Thanks a ton guys, and can't wait to get active in this portion of MBworld forums. Take care brothas
What you are likely to have however, is the cylinder walls are probably a little corroded. Not big time but enough to mean you could lose the piston rings if you don't drive it real soft for a few days and let them polish themselves smooth again.
As aforementioned, general servicing things aren't a bad idea, flushing/changing all the fluids from top to bottom before a startup would be good. And the plugs. I like those Bosch platinum-fusion type, expensive but great plugs for these period Merc engines.
Then drive with little loading on the motor for a couple of days, do some soft kilometres and see where you're at from there. Probably be fine.
