190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
89 190E 2.6 transmission problem
Old Jun 4, 2004 | 09:36 PM
DougandhisC280's Avatar
2008 SLK-280
Ok, so I just bought 190 about a minute ago. The transmission won't shift out of second gear. The lady I bought the car from said it happened when she put in the new engine. Is there anything like a sensor that controls this? Any help would be greatly appreciated. -Doug
Old Jun 7, 2004 | 05:35 PM
E-Klasse's Avatar
W205 C300
I would check the shift lever linkage to see that D position is not putting it in the 2 position.
Old Jun 7, 2004 | 08:21 PM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Welcome to the club, Doug. My 190E is kinda similar, it won't shift into 4th gear when in D... I thought it might be the linkage, but there's nothing between neutral and D, so I am sure it is in D. So like E-Klasse wrote, check it... you can try moving it slowly forward out of D to see if there's any more gears.
The kick down solenoid is something to look at; actually after going through all the transmission tech stuff, I've decided to just leave it and get a reman trans for around $1500.
-s-
Old Jun 7, 2004 | 09:25 PM
2008 SLK-280
Thanks for the replies. I have already checked the things you mentioned. There is a random cord hanging off the enging with the plug broken off of it. I can't see where it goes but do any of you know if it is a sensor that tell it when to change gears?
