190E 2.6
so basically I recently took a relative 190E 2.6 that has been sitting for over 20 years the odometer shows 76k km only. anyway i faced few issues trying to restore it.
*Replaced fuel pumps and lines
*Replaced water pump
*Replaced engine coins on both sides of the block
*Replaced Brake discs and pads
*Replaced the radiator and radiator hoses
Currently the car is leaking from the brake booster and brake lines.
also the car starts fine but it stalls if you pressed the gas pedal hard ( anything above 3k rpm) and I can't figure out the issue
if anyone have a clue on what to check for and replace please let me know
forgot to mention in the post that the car has a rusted back exhaust and Broken O2 sensor. Can the O2 sensor be the cause of this issue or its something as simple as cleaning the AFM ?.
what else can cause this issue ?
how can i check for vaccum leaks. or if the injectors are clogged or if the fuel distributer is bad ?
is there anything else i can check ?
how can i balance the throttle to the EHS I couldn't find any info on the internet.
i did fix the entire breaking system no leaks there. checked the brake cylinder and brake booster aswell as the vaccum lines
all work just fine with no leakage.
i just ordered new fuel injectors and distributer cap aswell as new spark plugs wires. Hopefully this fixes it.
if you have anything else to look for pls let me know.
so i just finished fully painting the car and getting it prepared to be registered.
and all of the sudden i started noticing smoke coming from the car.
i can't differentiate if its a bad head gasket or bad piston rings or both.
the car blows light white bluish smoke from the exhaust, the valve cover breather and the radiator resevoir. increases as you rev the engine. also the oil filler cap had white milk shake just starting to show. (not planning on running the engine untill it gets fixed to avoid nock)
at this point I'm lost because if its the head gasket thats bad then i would change it easily however if its the ring pistons then i should scrap the engine and get another one in.
my question how can i differentiate between a bad piston ring and bad head gasket leak.
also if you recommend any other engine that would be easy to install in the car I'm open to all suggestions.
side note today i tried to start the car but it seems like no fuel gets to the injectors. But it reaches the fuel distributor. I tried pressing down the fuel distributor plate while someone cranks the car and it just starts fine, but once i release the plate it shutsdown. Basically fuel only reaches the engine when the plate is slightly pressed. What causes it and how it can be fixed ?.
and where i live the 190E is considered a rare car and barely anyone knows how to work on it. Thats why i need to do things myself.
I believe the entire issue is due to a misplaced vaccum lines. I noticed few lines that are just out in the open like the one for the EZL unit and another one coming from below the fuel distributor. Two lines actually come from below the fuel distributor. One goes towards the top of the head while the other one is connected to the corner of the intake on my car.
Also i noticed a missing line on the driver side which i believe is the one for eco Guage.
Where can i find a vaccum line diagram ?
This line goes out of the EZL but can't figure out where it connects to ?
this line I also noticed missing its connection. on the other side of the fire wall its connected to 3 lines but idk what its for and where it connects to.
this thing is on the driver side and its disconnected from both sides where does it connect to ? does it connect to the hole in picture B ? if so where does the other side connect to ?
so basically the garage that fitted the engine in connected this vacuum outlet to the lower nipple on picture (E).
this is a clarification over where the line from pic (D) is connected to. the upper nipple is connected through a vacuum hose to the head of the engine.
I have this wire coming out of X11 port that I can't seem to find where it was cut off from.
Also this wire that comes out of front of the engine. Engine VIN is 103 983. As far as the vacuum lines i somwhat sorted them out with some online diagrams but still not 100% sure.
