Strange Duty Cycle reading and Code 17 "O2 sensor grounded"?
I sure hope it is not an ECU malfunction again but this time with the O2 sensor circuit. You and your GS should try and pull up the carpet and attempt to measure the voltage.
I think you have done this before so I will not explain that part of it.
Remember the ground is any chassis ground you can find around, the door strike plate works.
Engine fully warm and disconected from the ECU wire .44V
Connected to ECU with copper wire between contacts engine fully warm between .09 at idle and .75 bouncing rapidly at idle but went to .87 at 2500RPM
Duty Cycle still erratic and bouncing around quickly. It seems the O2 sensor isn't dead. When I checked the duty cycle with the sensor wire disconnected the meter sat at 50% which if I recall means no signal from O2 so the ECU seems to be getting something from the sensor and reacting even if nor what it should be.
X11 Error Code #17
I will try tomorrow to ground the O2 sensor with a clip to a solid ground and see how that works
You may need to hook up an EHA current meter again Laura and observe what it is doing during cold and in transition to the lambda control and beyond.
You have made a harness for that correct?
The fact that your duty cycle is railing to one side is not good at all. Not normal Laura.
engine running cold +3.8
" " hot +13.3
Code Reader always returns to 17 flashes O2 sensor grounded etc.
Maybe another messed up ECU?
The ECU was an ebay find if I recall correctly. It could be the ECU or the wiring or the O2 sensor. Let's think about some more diagnostic testing for the next time your GS returns.
Did you decode what the 50% static duty cycle mean. Is it the same? (O2 sensor shorted to ground?)
You still have the old ECU correct? I know it had the cold start problem but it was OK running hot, correct?
It should just say "EHA current out of range" instead. Because that is what throws that code.
So now we have to find out what makes the EHA current go so high. I have seen posts with various causes.
Air leaks, EGR issues, coolant sensor issues, etc. etc.
The first decision making branch point is the answer to this question:
Is the emissions system just responding properly to all the input it is receiving or not.
So you will need to determine if the emission system just reacting normally to a fueling issue.
Do you believe that the engine is running super rich after it warms up? Do you smell gas from the tailpipe?
The ECU is trying to enrich the mixture but it maybe just doing the right thing because the FD is not delivering the fuel the engine needs.
Maybe check the spark plugs (all of them for signs of super rich mixture).
I'm afraid you may have to re-connect your fuel pressure gauge for a quick check.
When he brings the car over perhaps check the spark plugs, if they look normal, I'm afraid we will need to look into the FD being the culprit.
What I would do as a simple elimination is this.
When the car is back and after it reaches operating temp, disconnect the battery, swap in your old ECU with the cold start problem. Reconnect battery.
See if it behaves the same (meaning EHA railed to positive). If it does, your ECU is not the problem, swap your new one back in. Your ECU is not the culprit.
Then take some fuel pressure measurements again. And see what you have.
This would be my advice.
- Cheers!
So now that is fixed and the hot running is fine but your cold start problem is back.
I wonder if you damaged something during the EHA current test? And now you are not getting the fuel enrichment during cold.
Can you please reconnect the EHA current meter and measure it one more time in this condition of no start.
