Help Source Fuel Tank
Fuel tanks are gonna be tricky to find locally, over here the junkyards always punch holes in the tank.
If you don't mind paying shipping, we've got a lot of MB dismantlers here in CA. This yard always seems to have a lot of parts.
https://www.mbiparts.com/search?manu...enz&model=190e
i did check LKQ, they crushed the one 190e I used to scavenge earlier this year and they rarely ever get any Mercedes. Hopefully I’ll find someone parting out a car on Craigslist at some point.
No shop will help remove and clean my current tank.
I was just going to remove it because the JY forgot to punch a hole in it to remove the fuel. It is hard to get them here in CA because they are all punched.
Unfortunately, I had trouble removing the fuel line, went home to get a more suitable wrench, 2 days later the car was crunched before I could get back to it.
Otherwise I would have one for you.
Never seen a tank that is not punched already since ....
Good luck with the search.
I may just save up and buy a new tank if I can’t find a decent used one. I was able to get the part number from the dealer (2014700801). They seem to be going for $450-$650 across different sites.
Unfortunately the tank would not come out of the trunk with the hose on. Easy to remove with the trunk out I'm sure. And it is very tight just like the sender unit nut.
I could have cut the hose but then again I was really after the hose which is NLA and the tank was just a bonus.
A plumbers wrench (which I have and was going to bring along in the next trip) would do it. The one that is used to tighten kitchen faucets with the swivel head.
Surprised the tank is not NLA already, at least you have a last resort. Only $36 + $6 core at the pick and pull but then you have to clean it.
Not sure if you remember all I’ve done to the car since you help so many different users….but I’ve replaced almost all critical fuel components and the car starts to buck and stall at half a tank specifically. No other issues with starting, idling, nor driving. Old fuel pumps were noisy and clogged with rust and the new ones make noise at half a tank so I think addressing the tank itself is the logical next step.
In your guys’ opinion, is it worth it to try and put in a new strainer first? My mechanic won’t do it and advised that I don’t touch it but I honestly can’t imagine why not?
Lastly, Is this the tool you planned to use?
https://www.harborfreight.com/12-inc...hoCTMYQAvD_BwE
That one you have will not work, it has to be 90 degree angled swivel in my opinion.
Yes I remember your problem. I'm not sure why you are having fuel pressure/flow problems at half full tank. I'm sure you tried to open the gas cap to see if it helps.
It is a gravity fed system but maybe yours need some extra fuel pressure that is natural with a full tank.
The strainer must be in the end of that main fuel line. My parts book does not even show it for some reason. I suspect that may need changing too in your condition but seems like a difficult job to me.
The tool Dolucasi recommended from harbor freight works great. Never done the fuel strainer w/ it, but I use it for plumbing purposes.
Let me know what price that MB recycle quotes you on a tank too. It seems like with most MBs as long as their driven, the tank is fine.
There is a shop in Greensburg Pa. that cuts them open, cleans, coats and welds them back together. Might be worth looking into. I had two done by them.
http://www.gas-tank.com
Other than a new strainer are there any other parts I might need?
Same goes with the fuel filter.
I can't think of anything else that can be cogged up (other than injectors)
I’ll get around to cleaning my tank one weekend and try to start a new post on how I go about it.
will a fuel line and fitting from any other models work? Maybe from a 300e? I want it on hand before I attempt to remove mine
