Help with DTC error code number 10 and car flooded when starting
am I correct?
The throttle position switch is brand new and functioning properly I have verified that. Before I dig into the car and look at wiring diagrams and try to figure out what’s going on. I was wondering if anyone could shed some light on this.
10 Throttle Valve Switch and/or Idle Speed Contact
Which probably means any time the Throttle valve switch is on open state (between closed throttle and WOT) if the Idle Speed contact (microswitch) is in the wrong state (suggesting you should be in idle) that error code is thrown.
So it could be either switches. If you already checked the TPS perhaps check your microswitch as well.
Take my advice with a grain of salt though since I've owned mine for eons and have not had to deal with your issue.
- Cheers!
when the car does start it runs fairly well with some odd behavior. If you press the acceretor up and down several times the car is fine and then all of a sudden the throttle will stick and the RPMs will rev higher and higher and higher you have to just shut the engine off.
then if you try to start it again you’re back to the flooded situation. Other times when it will start it will be in that full throttle situation and you’ll just have to shut it off and then you’re back to the flooded situation. Seems like there’s something going on with the full load and idle sensor position
Your error code and the car's behavior could be unrelated.
If you erase the code does it come back? Sometimes those codes are in there for long periods of time.
Since I have an EHA gauge in my console, I can tell you that the EHA current only goes up by an additional 4mA or so from where it is when you activate WOT.
So a WOT signal may or may not be the culprit here even if there is a malfunction. As a comparison in chilly weather (50F) if you start the car cold the EHA current will start out a 10mA-15mA for warm-up. So ~4mA boost while rich should not completely flood the engine.
You have something else going on. Unplug the EHA and see how the engine behaves (after you warm it up)
if you erase the code, it comes right back as soon as the engine runs.
there are a couple of additional items to note… When the car does start and run it runs rough, almost like it’s missing.
Yesterday I did a fuel pressure test and was getting 5.4 bar in working which I believe to be in spec with the FSM. I was not able to get an accurate reading in control but with my gauges hooked up an EHA unhooked the car started and ran every time but not very well.
disconnecting the EHA at this time makes no difference.
I was beginning to suspect that the O2 sensor might be bad but I’m currently getting 40ma off that which I also believe to be in spec.
this is truly a frustrating predicament.
So if you see no improvement and the car was running just fine prior this episode a few weeks back we can assume the FD was adjusted properly mechanically.
So this would eliminate a bunch of suspects, ECU, all sensors including O2 sensor, etc. etc except the EHA valve. That could still be messed up and stuck.
What is the idle when it is really running rough? Also do not rule out ignition issues. if the fuel is not burnt properly it will have the feel of rich mixture.
Are all spark plugs the same? Meaning wet with fuel.
The mystery is the code 10. I still think it maybe unrelated. But again when you unplug the EHA it can not effect the fuel mixture, now it could effect your idle speed which is why I asked the question about the idle speed.
Here is the link to the video
it is not surprising the the CEL light is triggered when you disconnected the EHA
It is not surprising that the car runs rough before it warms up with the EHA disconnected
Let it warm up and verify that it is indeed still messed up warm.
So since this was a JY destined car, we do not know the health of the FD.
I would put the FD itself on top of the list as the culprit. Especially at such high mileage.
Mine got replaced at 150K miles, with very similar symptoms as yours.
If you have another FD you can swap in, that's where I would start.
Happy Sunday!
Any time you change the FD or AFM you need to adjust the mixture. What exact parts did you swap out?
