190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
WTF 2.3-16v performance parts
Old Oct 14, 2004 | 11:59 PM
W201_Savage's Avatar
does anyone know of any places to find high flow filters, performance chips... i've looked all over the net and cannot find much
Old Oct 15, 2004 | 02:05 AM
MTI's Avatar
MTI
'85 190E 2.3-16 '99 C280 '11 GLK350
The Bosch CIS isn't really "chip"-able. The air intake is already a high flow, cold air intake. Save your money for maintenance.
Old Oct 16, 2004 | 02:45 AM
oh thanks, i didn't realize it was already a high flow, i would like to put a cone filter in and elimintate the airbox, i just love the sound and it would probably boost hp a little (not much but whatever), with a housing around it... the reason i asked about the chip is because i unfortunately i own an automatic 2.3 -16... one of only 400 in the u.s. i have heard. this weekend i'm going up north to look at a 5 speed with lower miles. so if anyone is looking for an automatic 1986 2.3-16 pm me. the transmission is solid and smooth and will redline when 2 and 3 are used. i don't know much about the top speed on it cause i haven't pushed the car except once (ive owned it for a week). it has stock shocks with eibach springs and 17 inch american racing rims. euro headlights and clears, 10 inch infinity sub 160,000 miles
Old Oct 16, 2004 | 01:13 PM
MTI's Avatar
MTI
Using a cone filter, even with that chrome plated "heat shield" in the 2.3-16 is likely going to DECREASE performance, since you'll be drawing in the warmer engine compartment air. For any hope of more HP, you'll need to plumb the system to draw cold air from the bumper area and avoid the intake of water during rains. It may be hard to resist the need to be "trendy" but you have to acknowledge that the folks in Stuttgart knew what they were doing when they designed the 2.3-16.
Old Nov 7, 2004 | 07:43 AM
mbzsd's Avatar
86 190e 2.3 16V
I just bought this car last week and the rear suspension is rock hard the notation from the former mechanic says the shocks are blown, What are my options? Unfourtunatly it's and auto. Thanks for any help.
Old Nov 14, 2004 | 09:54 AM
23BANG's Avatar
86 190e 2.3 16V
Check the hydrualic fluid. The rear supension is Hyrdo pneunmatic. This might be what is causing you ride to be hard. Also remeber this is sports car, the suspension is kinda harsh. I have both a '84 2.3 16 and a 190e the suppension difference is quite noticeable. If the shocks are bad (which i highly doubt, you can get new ones from blistein http://www.bilstein.com/pdf/PassengerCars.pdf
Good luck.
Brian
Old Nov 16, 2004 | 01:35 AM
Mit's Avatar
Mit
190E 2.3-16V 300CE 3.2
Its not the shocks. It most likely the Air Cell's, $110 each from Performance Products (32-001).
Or you can rip out the self-leveling stuff and put in some sportline struts.
Good luck!
Mit
