Problems with my 190E
Anywayz I'm having some problems with my gauges.
My fuel gauge is stuck at empty, the oil pressure gauge is stuck at zero, and the water temperature gauge is also stuck at zero.
Does anyone know what the problem could be? I have already checked the fuses and they seem to be in running order.
Any help would be greatful!
'88 190E 2.3L
I would still strongly suggest replacing the fuse for the cluster. Those plastic/copper torpedo shaped fuses have a fustrating ability to look good, but upon very close inspection, show up as blown/cracked. There should be some spares in the fuse box, or just get some from the parts store.
Once you've completely ruled out the fuse, then there are two other likely suspects, the wire harness to that side of the cluster . . . or . . . the ground joint to that side of the cluster. The wire harness/plug is unlikely since it's usually pretty firmly pushed in place, but that is a possibility. The other issue, the ground joint, causes the one side to fail when, over time and with the help of vibration, the solder joint that connects the left gauges with the speedometer section, breaks and you loose the ground. You can test for a break, after removing the cluster, with an continuity/ohm meter. Repair is via a jumper wire to provide the ground.
To remove the instrument cluster, will I need to use the special Mercedes tools? If so is there any other type of tool I can use in substitution for that?
Thank you for any and all help!
Worst case scenario, take it to a dealer, they'll fix it pretty fast for a pretty penny.
