190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
Any Experiences with Brake Pads ?
Old Nov 28, 2004 | 10:37 AM
jjkuhnjr's Avatar
190E 2.6 + 560SL
Question Any Experiences with Brake Pads ?
Greetings.
I'm in the market for a new set of brake pads for my 89 190E (2.6). I checked an online supplier and found more varieties than I could have imagined. Does anyone have a good recommendation and/or experience with a specific type, brand and supplier ?
Thanks.
Old Nov 29, 2004 | 09:35 PM
RunInColorado's Avatar
2007 CLK350 Sport, 2006 E320 CDI, 1978 Cessna 152
I have heard that bekkers sells good pads. (I know they sell a couple of brands but thats all I know). I had some pads and discs put on a 190D by a local shop (I dont know the brand) but I do alot of interstate commuting, 30 miles a day, and do alot of 60-0 stops. They never last more than a year. I hope that helps somewhat.
Old Nov 30, 2004 | 12:54 PM
2PHAST's Avatar
500E Signal Rot
I used PBR (Axxis) Metal Masters on my W201 and they worked great, both on the street and the track, no noise, very little dust and great bite with no fade. Very inexpensive as well.
Old Nov 30, 2004 | 05:35 PM
jjkuhnjr's Avatar
190E 2.6 + 560SL
Thanks for the Responses.
I ended up ordering the Axxis Metal Masters. We'll see how it goes...
Old Nov 30, 2004 | 10:17 PM
electric blue's Avatar
Brake pads
I would have considered Textar as my choice in Brake Pads. They do make OEM pads for Mercedes. Also Pagid and ATE make a good pad. I have used them all and can tell you that if you do alot of stop and go driving you will wear any brand of brake pad down.
Old Dec 1, 2004 | 08:52 AM
jjkuhnjr's Avatar
190E 2.6 + 560SL
Too funny.
The Axxis fronts turned up as "Out of stock - backorder" and would have held the rest of the shipment up. Since it was a tossup between Textar and Axxis, I changed the order to Textar . Well, it's nice to get reassurance...
BTW, it seems to be a common response that the pads are good for about a year of normal use. It's really not such a big deal since they're so easy to change, but why such a relatively short life ?
Thanks for the input,
jjkuhnjr.
