W201 Max wheel height/width
With some quick and dirty measurement it seems 17x7 rims would fit fine, but would i be able to get away with wider rims (say 17x8). I'll probably also get lowering springs so thats somehting to consider aswell.
Im also unsure as to how the offset is measured.
(my eyes are on these : http://www.carshine.com.au/Wheels/Wh...o%2020x9.5.jpg ) )
Wheel offset is measured either in positive or negative numbers. Positive offset is how most factory and aftermarket wheels are designed. Zero offset means that the wheel mounting face (what you see when you mount the rim) is exactly in the center of the rim width. Positive offset occurs when the hub is not in the center, but is closer to the center of the car. The distance, in millimeters (even if the rim is measured in inches),that the hub mounting face is from the center of the rim width determines the offset measurement, so the bigger the number, the more the hub face moves to the inside of the rim.
Negative offset is the reverse, where the hub face moves outward, away from the car.
i did some more measuring and i think i could get away with 17x8's all round, thats if they are in stock, otherwise i might just stick with 17x7's. 8 inchers would give the car a nice aggressive stance i think (even tho it is the softest mercedes money can buy :P ).
I had a look at the AMG "Hammer" rims that many people put on these cars but wasnt a big fan, i think the rims is have in mind will suit the car very well. Especially if i get some good lowering springs. Actually i was pondering the worth of full blown coil-overs shocks, but that would probably be a bit excessive for a cruiser.
That was just a random idea tho, lowered springs is good enough for me. Thats also why im not really considering any performance modifications coz it seems kinda pointless for a little 80kw car.
They do make a set for the 1.8 - 2.0l and a different set for 2.2D, 2.3E, 2.5D 2.6, etc.
