Mar 29, 2025 | 10:21 AM
Quote: I think I have this issue as well, from the Driver's side A Pillar, it seems more so on the Driver's Side Mirror side of the A Pillar, more noise than there should be at modest speeds. I also notice it from about 35 mph plus.
The above dealer blaming it on the PPF? What a joke. Is this what I will be up against with MB Service? (This is my first MB, was previously mostly Porsche and BMW.)
not all dealerships are created equal, might not blame the same thing at a different dealership.
Reply 0
Mar 29, 2025 | 12:05 PM
Yeah it was very strange. I’m also getting random rattles occasionally, and they even claimed they “fixed” one that was near the front dash speaker cage but didn’t actually. I’m definitely going to try a different dealership with my issues, and I encourage you to do so as well. Please follow up if they end up fixing the wind noise for you!
Reply 0
Mar 29, 2025 | 01:55 PM
Quote: Yeah it was very strange. I’m also getting random rattles occasionally, and they even claimed they “fixed” one that was near the front dash speaker cage but didn’t actually. I’m definitely going to try a different dealership with my issues, and I encourage you to do so as well. Please follow up if they end up fixing the wind noise for you!
not only do I have the wind noise, but at least 6-7 different rattle/buzzing locations in the cabin. The build quality behind the nice Napa leather is atrocious, and worse than the worst of Ubers I’ve been in
Reply 0
Mar 29, 2025 | 08:11 PM
Quote: not only do I have the wind noise, but at least 6-7 different rattle/buzzing locations in the cabin. The build quality behind the nice Napa leather is atrocious, and worse than the worst of Ubers I’ve been in
That really stinks : (
Reply 0
Mar 30, 2025 | 02:50 PM
Do you have any plans to fix it like dealership visits or felt tape?
Reply 0
Mar 30, 2025 | 04:59 PM
Quote:
Love the white with the black wheels
Reply 0
Mar 30, 2025 | 06:50 PM
  #32
Quote: Do you have any plans to fix it like dealership visits or felt tape?
I’ve so far done around 10 sessions in my garage disassembling panels that are likely culprits, and finding insane sections of hard plastic sitting directly against more hard plastic-absolute shocking discoveries that have blown my mind as to how these were approved and placed into production. I have been creating barriers using felt fabric tape, and while I have killed maybe 4-5 rattle zones, sadly there are many many more that I can’t locate yet.
no plan to involve a dealer as I know they will be useless.
there are also substantial amounts of areas like the interior door handle, main central screen, console etc that make a “crunching up an empty plastic water bottle sound” if I drive over a rough bump.
Reply 0
Mar 30, 2025 | 06:56 PM
  #33
Quote: I’ve so far done around 10 sessions in my garage disassembling panels that are likely culprits, and finding insane sections of hard plastic sitting directly against more hard plastic-absolute shocking discoveries that have blown my mind as to how these were approved and placed into production. I have been creating barriers using felt fabric tape, and while I have killed maybe 4-5 rattle zones, sadly there are many many more that I can’t locate yet.
Sounds tedious : ( , hope you get them all
Reply 0
Explore
Mar 30, 2025 | 08:24 PM
  #34
What car do you have? Which panels have been troublesome? I have had all the panels off from the rear seats back and I found good insulation to keep things from rattling. Sounds like you're not seeing any of that?
Reply 0
Mar 30, 2025 | 08:48 PM
  #35
Quote: What car do you have? Which panels have been troublesome? I have had all the panels off from the rear seats back and I found good insulation to keep things from rattling. Sounds like you're not seeing any of that?
GT55 2024. So far I’ve removed and taped up the rear panel of the hatch, the 3rd brake light and all surrounding trim (this piece is a rattling nightmare!!), the trim piece around the top of the rear seat divider area leading to the trunk, panels by the seatbelts, applied pad tape to the passenger seat belt receptacle so it doesn’t rattle against the console, both headrests rattled when not in the pushed back position, lower panels of the passenger footwell are a rattle nightmare. I’m probably missing a few as I have blacked out from rage that I’m spending my limited free time chasing this nonsense around.
but still, the worst of all, is the rattle in the trunk which triggers on when I hit the gas pedal hard, and the pitch of the rattle actually follows the pitch of the engine!!! Disastrous for the experience. Even my wife commented on “what’s that sound”?
Reply 0
Mar 30, 2025 | 08:57 PM
  #36
Quote: GT55 2024. So far I’ve removed and taped up the rear panel of the hatch, the 3rd brake light and all surrounding trim (this piece is a rattling nightmare!!), the trim piece around the top of the rear seat divider area leading to the trunk, panels by the seatbelts, applied pad tape to the passenger seat belt receptacle so it doesn’t rattle against the console, both headrests rattled when not in the pushed back position, lower panels of the passenger footwell are a rattle nightmare. I’m probably missing a few as I have blacked out from rage that I’m spending my limited free time chasing this nonsense around.
Wow that stinks. Could somehow the little rubber/foam pieces that stop this get missed on your car?
Reply 0
Mar 30, 2025 | 10:10 PM
  #37
Quote: Wow that stinks. Could somehow the little rubber/foam pieces that stop this get missed on your car?
no, I think it goes far beyond those foam washers, it’s the structure of the plastic panels sitting against, or directly on other hard plastic. This creates creaking, buzzing, and also changes severity with temperature. Brutally painful!
Reply 0
Mar 30, 2025 | 10:56 PM
  #38
Quote: no, I think it goes far beyond those foam washers, it’s the structure of the plastic panels sitting against, or directly on other hard plastic. This creates creaking, buzzing, and also changes severity with temperature. Brutally painful!
Is your car a 2024 or 2025?
Reply 0
Mar 30, 2025 | 11:22 PM
  #39
Quote: Is your car a 2024 or 2025?
25
Reply 0
Mar 31, 2025 | 01:41 AM
  #40
2024 GT55
Reply 0
Apr 2, 2025 | 11:51 AM
  #41
I'm still have not go thru with trading my 2019 AMG 63 sedan for a 2024 GT 55 despite over 20k on discounts and what I asked for my trade, I went back to the dealer and test drove the car again for almost an hr, the wind noise is there and some rattles tho I have to reall pay attention but still , build quality is mediocre at best, my 2019 does have some noises , including wind noise , I had a 2016 AMG Gt S prior and it was a rough/stiff ride lol.
Not a 100% sold on this new version, maybe with some more discounts,
Reply 0
Apr 26, 2026 | 04:30 PM
  #42
You ever get your wind noise issue resolved?
Reply 0
Apr 27, 2026 | 08:34 AM
  #43
Hello all, I've been getting some rattles and squeaks from around the infotainment cup area. It drives me nuts and I'm hesitant to bring it in because as someone else said it probably won't get resolved. My question is has anyone else heard these? Any thoughts on how to resolve or is it a turn the music up and deal with it situation?
Reply 0
Apr 27, 2026 | 05:53 PM
  #44
Bring it in. Ask if a tech can do a ride along with you. Keep bringing it back if it doesn’t get fixed.
Reply 0
Apr 28, 2026 | 01:22 PM
  #45
Ok will do thank you for your response!
Reply 0
Apr 30, 2026 | 01:27 PM
  #46
Per my comments on my review thread, I am one year in and had a visit to the dealer for my A Service and asked them to look at the wind noise issue. They said it is "normal" due to the frameless window design, which is BS.
I am very frustrated by the wind noise, I absolutely love the car other than that issue, but that issue is so bothersome that I may get rid of the car just because of that. Life is too short to be annoyed.
I am curious if the 2026's have the same issue (mine is a 2025), and when the 2027's come out, will they have the same issue. I would bet Mercedes is aware of the issue and will quietly work to fix it for future cars, if it is possible to fix.
I just invested in Ceramic Rotors and Pads and custom 20" Winter Wheels for the car, so I would like to get myself to keep the car if I can.
Reply 0
Apr 30, 2026 | 02:37 PM
  #47
Well, my 2027 car is month’s away but I’m tuned into this issue already and will report back. That wind noise isn’t “normal” for frameless windows. I haven’t owned a Mercedes one but the others all adjusted the windows every time I closed the window to ensure a good seal. Imperfections in the rubber seal and/or a slightly misaligned door or window could cause tiny leaks and the noise. You can try applying silicone grease to the seal, stuff like Shinu Etsu. It’s also a good idea to periodically apply this or some other rubber appropriate protectant on the seal to prevent it from drying out, which can make the noise worse.
How much were your aftermarket ceramic rotors if I may ask? Brembos? That was one option I got on my car.
Reply 0
May 4, 2026 | 04:25 PM
  #48
Tried the Shinu Etsu - no change whatsoever. Just poor engineering, apparently...
Reply 0
May 4, 2026 | 09:07 PM
  #49
They need to adjust your window. They remove your inside panel, and it and be adjusted in multiple planes. The car didn't get designed for wind noise etc. Tell your dealership to do the work and fix the issue. This is a very easy fix. Snug the glass up.
Reply 1
May 4, 2026 | 09:10 PM
  #50
This spec looks very nice.
Reply 0
