GT/C192/R192: Adaptive transmission reset
I drive AMGs or similar performance cars primarily in manual mode. Pretty much about 90% of the time at least. Partly a habit of having driven manual transmissions for over 20 years. I only let the transmissions shift on their own in the Comfort/Normal modes with moderate driving around town, in stop&go traffic which I don't do a lot and when just cruising along on a long road trip with DISTRONIC engaged. Most of the rest of driving I do in Individual mode, which in AMG's case I configure to put the powertrain in Sport+ and transmission in M and the suspension in the middle Sport setting for a good balance between handling and comfort. Pretty much all my regular highway driving I do in M and Individual mode. So I go between Individual mode on the highway or faster open roads and Comfort with the transmission in automatic mode around town, and I use Race with transmission in M for fun canyon roads. I've driven every performance car ever like this using the respective available modes. Some of them don't/didn't have an equivalent mode for Race, so those I generally don't like as much as they don't offer another mode above my regular sporty driving mode I can select for closer to the limit driving in the canyons.
The result is that the transmission algorithms essentially only adapt to my moderate driving style and end up being fairly smooth at low speeds as I do all the spirited driving shifting myself, so the adaptations don't have to find a compromise between my moderate and spirited driving styles. Having an understanding of learning algorithms as a software developer the more consistent your behavior is, the higher the chance they learn correctly. If you end up all over the place, they don't really know where to settle on the spectrum. Some more modern learning algorithms are able to learn different behavior based on your location, but I'm not aware of any of those being used in cars. One such algorithm that comes to mind is the optimized charging feature in iOS which tries to determine your phone charging habit at each location where you charge and then pause charging at 80% and only finish charging to a 100% shortly before you typically take the phone off the charger. But just like as said, this algorithm doesn't work if your charging habits are all over the place and at vastly different times. So consistency goes a long way.
FWIW, I had a jerking issue early on when going from P to D or R. That did turn out to be an adaptation issue, because I didn't bother putting the transmission in P whenever I parked the car and simply turned off the engine and let the transmission go to P on its own. I stopped doing that and explicitly started putting it in P, which w/o resetting the adaptations it relearned whatever it needed to and within about 2 weeks, the jerks went a way. What I'm trying to say is that these transmissions learn on a continues base and just changing your behavior can result in clearing the issue, or as I said before if you continue a certain behavior and/or driving style, the issue can just return after resetting the adaptations.
FWIW, I had a jerking issue early on when going from P to D or R. That did turn out to be an adaptation issue, because I didn't bother putting the transmission in P whenever I parked the car and simply turned off the engine and let the transmission go to P on its own. I stopped doing that and explicitly started putting it in P, which w/o resetting the adaptations it relearned what every it needed to and within about 2 weeks, the jerks went a way. What I'm trying to say is that these transmissions learn on a continues base and just changing your behavior can result in clearing the issue, or as I said before if you continue a certain behavior and/or driving style, the issue can just return after resetting the adaptations.
https://www.mbusa.com/en/owners/manu...on-breaking-in
looks to be an extremely wide spread case with C43 using our same transmission
