Anyone figure out the cargo area rattle?
Old Jul 17, 2017 | 08:21 PM
JB C63S's Avatar
2016 GTS, 2016 GLE, 2013 SLK55, 2015 GLA, 2015 GLK, 2014 E350, 2013 GLK
Mine sounds like it has a loose wire harness connector banging around when I hit a sharp bump. Dealer has not yet diagnosed...
Old Jul 18, 2017 | 03:07 AM
xbox's Avatar
G63 & 991.2 GT3 & AMG GT
Which side do you have it?
My noise is more of a creaking and to the left.
Old Jul 18, 2017 | 03:53 AM
DragonRR's Avatar
911 991 TTS, Audi RS6 C7 Performance Edition, AMG GTS
I've discussed my current progress in resolving this in my thread here: https://mbworld.org/forums/amg-gt-gt...hatchback.html
Mine is also from the left, more of a rapid ticking kind of noise. I'm pretty sure I've done a partial fix so far by wrapping every bit of wire and taping around the leading edge of the plastic hatch liner where it contacts the body but I still get a noise from time to time.
I also have a lovely buzzing noise from inside the centre dash area when I drive over coarse road surfaces.
Old Jul 18, 2017 | 07:29 AM
xbox's Avatar
Ooh, I missed taping the leading edges. Does seem awful creaky when you pull it around.
Away for a few weeks, so job for when I'm back.
Old Jul 18, 2017 | 07:49 AM
DragonRR's Avatar
It did indeed feel very creaky and as I mentioned the paint had been knocked through in a few places where the plastic nodules made contact. Mine now feels pretty solid... but still the final noise remains!
Something I've noticed that bothers me is that the panel gap between the hatch and the bumper is quite wide. The adjuster/strike plate behind the hatch liner was already at full retraction, I'm not sure if the lock part itself can be adjusted (maybe someone knows?) I've noticed pics of cars show a similar gap but others seem to be quite tight. Makes me wonder if this might have something to do with it all? Maybe the hatch doesn't compress the rubber seal enough?
Old Jul 18, 2017 | 10:26 AM
xbox's Avatar
True, the hatch just thunks down, but always seems to catch pretty easy, so maybe it isn't pulling tight enough.
Gaps look good on my car though.
Old Jul 18, 2017 | 03:39 PM
DragonRR's Avatar
I've checked the lock and unless I'm going blind it can't be adjusted. The adjustment is in the strike plate which is maxed. It could be slotted I suppose but my gaps are similar to yours Xbox, maybe slightly worse so it is probably the wrong tree.
Old Jul 20, 2017 | 03:51 PM
jrcart's Avatar
2008 CLK63 Black Series 2012 C63 Black Series 2014 SLS Black Series
Mine was the carbon fiber cross bar thing, it was always rattling and squeaking.
Old Jul 26, 2017 | 07:45 PM
AtTheGlen's Avatar
2024 Porsche 911 GT3 (992.1), 2026 Porsche Cayenne GTS, 2025 Taycan GTS sedan
Rear Hatch Rattle Was Diagnosed and Fixed
A few months ago I had a rear hatch rattle on my 2016 Edition 1 AMG GT S. It didn't upset me because I knew this was an early production of a brand new design. I'd hear the rattle when closing the hatch (I wish they had a pneumatic valve strut that cushioned the dropping speed/force) and when driving over a serious bump. The dealer's service dept was able to fix the problem and the rattle never recurred. Unfortunately, I don't know exactly what was done to fix it (it's a large dealership).
The dealer also fixed a creaking sound under the car in the area of the engine placement. This too was successfully diagnosed and repaired. The issue was with a crossmember and I had the sense that M-B/AMG was aware of the problem. It was not related to a small recall related to the torque tube, I believe.
Old Jul 27, 2017 | 05:04 AM
DragonRR's Avatar
I've updated the other thread but to recap on the steps I took to clear my rattles from the rear hatch area:
Adjusted bump stops on hatch (solved the original loud rattling)
Lined the plastic hatch parts where they touch metal/paint with Tessa felt tape.
Wrapped exposed cables in the hatch itself and the fuse box area with fabric wire wrapping tape.
Wrapped and re-seated a pipe which sits inside the metalwork of the hatch. I'm not sure what purpose this serves.
Pressed a few plastic cable trays into their proper positions
Replaced the bump stop paint protection film with 3M helicopter tape
Added Velcro HD felt side pads on top of helicopter tape
Replaced left bump stop with new. (A190 750 00 00)
Old Jan 2, 2020 | 11:19 AM
Surge's Avatar
W463 G550 / C190 GTC //prev: W204 C63 507 / R170
Very helpful post and thread!
My GTC has one or two very minor rattles coming from the rear hatch area. They are minor, and only noticeable on certain bumps. My AMG service tech is looking at the hatch adjustment now. Hopefully the fix is in one or more of the items you mentioned above.
Is it too much to expect that a $200K car is rattle free? It’s totally awesome otherwise!
Old Jan 2, 2020 | 03:11 PM
dlefty's Avatar
/////PRO
It’s a sports car, it should squeak, rattle, groan, and smell every once in a while!
Old Jan 2, 2020 | 07:01 PM
Surge's Avatar
I added an adhesive felt pad (like Felt Tac) where the lift gate spring loaded stops hit the PPF. That took care of the rattles for me. It’s now a bit harder to close the trunk but it’s worth it.
I noticed each spring can be adjusted. Does anyone know what the adjustment does exactly?
Old Jan 4, 2020 | 10:49 AM
Surge's Avatar
Can you clarify: “Wrapped and re-seated a pipe which sits inside the metalwork of the hatch. I'm not sure what purpose this serves.”
I don’t see a metal pipe anywhere. Did you remove the plastic trim of the hatch? Or are you referring to the metal tow bar?
Old Jan 18, 2020 | 04:03 PM
Surge's Avatar
Wrapped hockey tape around hatch striker (U-shaped metal bar that the latch grabs when the hatch is closed) - made a big difference!
Old Feb 6, 2021 | 07:49 AM
Greg Graham's Avatar
gt, gtr pro, sl65 black series, glc63s, slc43, a45 amg
I have same, a almost chirp type noise around rear shock tower
Old Feb 6, 2021 | 08:00 AM
Surge's Avatar
I had this and it was actually the hood! Check the hinges on both sides of the hood. Sounds counter-intuitive because the sound is coming from the rear; but sounds travel in this car unlike any other I’ve seen.
With the hood closest push up and down on the corners, at the base of the windshield. Check for play. I had play on one side. Chirping rattle went away when dealer replaced hinge.
