AMG Vendor Classifieds
Sponsored By:
Sponsored By: Premier Tuning Group
R1 Concepts| REPLACEMENT 2-PIECE CARBON GEOMET FRONT ROTORS! (CLS63, CL63, S63, S65)
Old Aug 8, 2019 | 03:35 PM
r1concepts's Avatar
Former Vendor of MBWorld
R1 Concepts- High Carbon Alloy Geomet Rotors!
Manufactured for european and heavy vehicles, our High Carbon iron formulations enhances noise dampening characteristics, while providing high strength, and increased thermal conductivity compared to standard discs, which increases durability. Each rotors is engineered to match the OE vane configuration, including OE split-core technology to ensure proper and maximum heat dissipation. Additionally, all cores are dipped with a specifically formulated paint in order to provide a smoother finish inside the vane structure. The smooth finish will improve air flow as well as reduce the amount of machining required in order to properly balance the finished rotor during the mill-balancing process.
Geomet Finish
After all the machining processes are completed, each rotor passes a 100% electronic inspection station that measures over 20 attributes to ensure that each rotor meets OE specifications. This further guarantees that each and every rotor delivered to you is trouble free. Finally, we apply a genuine GEOMET finish throughout the entire part, which promises to deliver superior corrosion protection. The GEOMET coating is processed dry, shipped dry, and ready to install without any additional preparation.
-Ready to install- No additional preparation needed. Saves time and money during installation process.
-Superior Corrosion Protection- Provides excellent cyclic corrosion performance when tested according to automotive manufacture's test methods incorporating heat, salt spray (withstands 400 hours), and humidity (SAE J2334, GMW 14872, Ford CEPT: 00.00-L-467, Asian CCT).
-Environmentally Friendly: Meets the following regulations: Environmental Protection Agency (EPA), Chrysler CS-9003, General Motors GMW 3059, Ford WSS-M99P9999-A1 (Hex 9), the EU Directives on End of Life Vehicles (ELV) and Electrical Equipment (RoHS).
Fine-Turned
The castings are sent to our state of the art machining facilities, where each rotor is machined to the tightest tolerances available in the market today. We can guarantee specifications of .010mm disc thickness variation (DTV) and .050mm maximum lateral runout. Though in practice, we regularly achiece .007mm DTV and .025mm maximum lateral runout. Then, the rotors are fine-turned to a maximum of 1.6 RMS. The objective of these strict tolerances is to create the smoothest possible finish, which improves initial break-in due to the increased contact between the pad and the rotor.
CL63 AMG, CL65 AMG, S63 AMG, and S65 AMG
FRONT 2-PIECE DIMPLED ONLY GEOMET ROTORS: $700 (PAIR) SHIPPED
PM OR EMAIL AT KEVIN@R1CONCEPTS.COM IF YOU HAVE ANY QUESTIONS!
Old Aug 21, 2019 | 04:34 PM
r1concepts's Avatar
Bump
Old Aug 31, 2019 | 05:13 AM
Acrimony's Avatar
dust
Bump.
Old Sep 11, 2019 | 09:25 PM
r1concepts's Avatar
Bump
Old Oct 15, 2019 | 05:53 PM
r1concepts's Avatar
Bump
Old Oct 30, 2019 | 08:05 PM
r1concepts's Avatar
Bump
Old Nov 6, 2019 | 12:54 PM
r1concepts's Avatar
Bump
Old Nov 22, 2019 | 06:05 PM
r1concepts's Avatar
Bump
Old Dec 11, 2019 | 08:38 PM
r1concepts's Avatar
Bump
Old Jan 14, 2020 | 05:57 PM
r1concepts's Avatar
PM if you have any questions!
Old Feb 12, 2020 | 05:50 PM
r1concepts's Avatar
Bump
Old Feb 19, 2020 | 05:55 PM
r1concepts's Avatar
PRICE FOR ROTORS NOW DROPPED TO $700/PAIR!!
Old Feb 25, 2020 | 03:05 AM
dlite922's Avatar
2007 W221
Question
@r1concepts your website says it's not available for 2008 S63 AMG. Are you out of stock?
Old Feb 25, 2020 | 10:00 AM
M1RAG3's Avatar
CLS550 AMG Pkg.
Great price! How much for shipping to Toronto, Canada?
Old Feb 25, 2020 | 01:41 PM
r1concepts's Avatar
Our website doesn't show the 2-piece rotors but we do have them available. You can purchase these directly with me.
PM sent!
Old Mar 1, 2020 | 03:03 PM
Todor Delchev's Avatar
mercedes s63 amg 2008
S63 amg w221 2008 front rotors and pads
Geomet Finish
Fine-Turned
hi do you have available front rotors and pads for s63 amg w221 2008
and what is the price ?
Old Mar 2, 2020 | 09:05 PM
r1concepts's Avatar
PM sent!
Old Mar 18, 2020 | 04:08 PM
r1concepts's Avatar
Bump
Old Apr 10, 2020 | 03:08 PM
r1concepts's Avatar
Special forum discount of 30% will be offered for the rest of the month! PM or email for orders!
Old Apr 17, 2020 | 09:34 PM
r1concepts's Avatar
Bump for 30% promo!
Old May 15, 2020 | 06:43 PM
r1concepts's Avatar
Sale has been extended until the end of May!
Old May 18, 2020 | 11:56 AM
kslater260's Avatar
2013 S63
PM sent
Old May 18, 2020 | 03:04 PM
r1concepts's Avatar
3 front sets left remaining! Plenty of rears available.
Old May 26, 2020 | 11:47 PM
auburn2's Avatar
S-65 AMG
I need a front set for a 2007 S-65. PM sent.
Old Dec 29, 2021 | 09:33 PM
Kevo79's Avatar
s63
Geomet Finish
Fine-Turned
I’ve been trying to buy rotors from you guys going on a year now but y’all stay sold out. Any info on when you will be restocking.
