Sponsored by: Innova
Help with Sirius Sat. Radio Cable (Wiring Harness) for 2005 CLK500
Old May 17, 2005 | 09:18 AM
Rosengoo's Avatar
Hello, I have a 2005 CLK500 that was made for the Canadian market and does not have the wiring harness for a Sirius Satellite radio in it. I have the actual Delphi radio but need info on the female connector that goes into it. It may be made by a company call Molex. It has 4 numbered pins in the actual Sirius Box. My guess is that 2 sets of these pins are plus and minus 12 volts for power and the other 2 are plus and minus 5 volts for data. The other two holes on the box itself are for fibre optic lines. The one connector that I am therefore looking for will have 4 very small female holes and 2 larger ones. Mercedes official term for this piece is a "SDARS MOST" connector. Can anyone please help with this part by looking for a part manufacturer and or part number? Your help is greatly appreciated. My email is: rosengoo at hotmail dot com.
All the best, Joel. (Toronto,Canada)
Old May 17, 2005 | 12:07 PM
wingless's Avatar
Debadged 6-Speed '05 C320 Sports Coupe
Wouldn't the MB parts be an acceptable option?
Old May 17, 2005 | 12:10 PM
Chip's Avatar
08 E320 Bluetec
I have heard that the US models built 03 and under have the same problem. You might have to go the aftermarket route. I'm not sure.
Old May 17, 2005 | 01:04 PM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
https://mbworld.org/forums/clk-class-w209/108281-help-sirius-sat-radio-cable-wiring-harness-2005-clk500.html
-s-
Old May 17, 2005 | 02:09 PM
ctC230K's Avatar
excites your girlfriend
i bought Sirius Starmate so I avoid these problems :p it matches the interior of my c230 perfectly and it fits inside the cigarette tray and i can close the door over it. plus it plugs right into the aux cable input, except now i'm getting an alternator hum on the aux line...
btw... i LOVE sirius so far. i even listen to that more than my ipod now.
Old May 17, 2005 | 02:12 PM
ctC230K's Avatar
The connector parts are made by AMP, not Molex. You will have a very tough time getting them separately.
Suggest purchasing a correct wiring harness from Mercedes and installing it. It will require two wiring harnesses... one for the power (the four pin connector) and one for the fibre optic lines. You'll also need the connectors that go into the rear SAM and wake up termination point, but that would be on a proper wiring harness. The fibre optic cables will hook in anywhere in the loop.
-s-
