JL Audio CleanSweep??????
www.jlaudio.com
JeannnBeannn
Leave the factory system in tact all the way to the amplifier. Do not go to the headunit and bypass the amplifier if there is one. The factory headunit in a Mercedes, especially COMAND wants to see the factory amp.Take the speaker leads from the factory amp (high Level) and put them into the LC6. From there you can build any system you want with low level outs (RCA's). The LC6 is basically a high end High / Low converter that does a great job. Used it in Honda's, Mercedes & BMW's with very good sound quality. I talked to my JL rep about the Cleansweep. He says it goes one step further by making up for the equalization in factory systems. Don't know how, haven't seen one yet. We will be sticking with Audio Control. Retail is $150. You will have all your factory steering wheel controls, navigation and speedometer display with any aftermarket system you want. For us, the LC6 has been the answer we have been waiting for.
Good Luck
hopefully i can upgrade my dogy bose system with this little device.
has everyone had install it yet?. negative or positive feedback?
