Mercedes Bluetooth (AWS) Phone Compatibility List
2003 E500
Hi all, new poster, but I have been surfing the forum for awhile.
Question is about the verison V710, is this compatible or does it have to be the MB v710 version that will be compatible with the v60 puck? The first post lists the phone as "MB v710". Sorry if this seems obvious to some. Thanks.
Originally Posted by deaddog
Xaveon
Not to be dense, but can you walk me through the process whereby you can cause the VCM to dial your Treo connected by BT? I ask b/c my E55 with a V710 will only voice dial numbers that I have put into the phones phone book. Those numbers than download into the Command and I assign a voice prompt to them. Since the Treo (or the blackberry) won't download phonebook, how can you use the VCM to dial by voice command?
John
Originally Posted by cristo
How do you get that software version on your Verizon RAZR? My Software version says GATW_01.0F.02 any thoughts if this will work?
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
1986 560SEL, 97 BMW 740iL
The newest software for the V3c is .04 now. Faster menu and if you update from .02, you'd still have OBEX feature. But I don't know if the puck use OBEX to transfer or just AT Command like the others.
#32
#34
04 E55
These phones are like black magic to me !! I am contemplating having Steve install the UHI kit on his sweep thru the states...but I have a Nextel PTT/Motorola i730 and I'm not sure if it will work with the kit.....I can always swap out the work phone but I need that PTT feature. Any ideas as to what I am going to need as an upgrade ? I am on the fence with the kit until I learn more. I am having Linguatronics installed so I really want the kit but need info !
#35
From everything I have heard so far, PTT is not supported by Bluetooth but normal phone calls are. If you get a PTT call, you'll still have to use your handset. Normal phone calls should be okay.
I believe that PTT calls are similar to SMS messages or some kind of data packet transmission so the system doesn't know how to handle them.
Anyone have experience with Nextel phones on the MB Bluetooth systems?
#37
S500/W220/2000
Brian, Would your system work in my car? It came w/ Startac phone, voice recognition, CD changer, etc., and I use a Motorola V3 RAZR now. The phone system in my car is useless as is.
![wall](https://mbworld.org/forums/images/smilies/banghead.gif)
#38
Whichever one is available (1 of 5)
I have been using my MB-V60 phone in my 2004 W211 for about two years now. Recently I heard that the V60 BT puck is now available, so I ordered one from AWS for around $325 (I think...). Beside the MB-V60 phone with Verizon, I also have the new Motorola Pebl with T-Mobile. I removed my MB-V60 from the cradle, inserted the BT puck, after a few seconds, the phonebook numbers from my Pebl were downloaded/uploaded into my command system. I tested a few numbers, and it seemd to be working fine. I then remove the BT puck, inserted my MB-V60 phone back into the cradle. After a few seconds, the numbers from the Mb-V60 phone were loaded into the command system.
I did not have anytime to play with the system further, but so far I am pleased with what I got.
#39
2020 S560,14 ml350, 03 sl55, silver, pano, slr cams, evo headers, lsd, 2019 s63 cab.
hlep me understand if the 2003 v60 mercedes phone that came with the s55 is bluetooth ready? i bought the puck and thought all v60 mercedes phones would be bluetooth. not knowing anything about phones i do not see anything on the phone menu about bluetooth or how to dial the code into the phone to find the puck.
#40
CLS55
Confirmed:
Nokia 8801 works perfectly.
Phone has a specific profile for the car, does not use headset profile. It auto downloads my phonebook and connects when I enter the car. It even takes my current ringtone and plays it thru the speakers
P.S. My service provider is T-Mobile
#41
Originally Posted by Redbud
Confirmed:
#42
#43
SLK350
Confirmed:
Confirmed:
Can you also comment on the battery life, especially when you use Bluetooth?
Cannot wait to get this phone now that T-Mobile picked it up.
#44
S 430
I see that the Razr phone works..will it work if its a Metro Pcs phone..the one posted is a cingular..does it make a difference who the carrier is as long as it is a razr...thanks
#45
Motorola Q
I just got my v60 puck and Motorola Q yesterday. After crossing my fingers, it seems to work great! Phonebook downloaded (limited to first 100 like the v60), caller ID came through, just no switchover for call waiting, no SMS. So:
CDMA (Verizon):
Motorola Q (3, 4, 5, 6)
[THE MORE NUMBERS ON THERE, THE LESS FEATURES IT SUPPORTS]
KEY:
1. No PhoneBook Download
2. No Call List Download
3. No 3 way
4. No SMS Download
5. No DTMF Tones
6. No Signal Strength Indicator
7. No Speed Dial
CDMA (Verizon):
KEY:
3. No 3 way
4. No SMS Download
5. No DTMF Tones
7. No Speed Dial
#47
Results have been good so far with V3c RAZR (CDMA) for Verizon. I'm not familiar with the Metro PCS version but at least you know that the CDMA RAZR for Verizon works successfully.
#48
Originally Posted by MagicO309D
For 100% assurance you need a handset with software level listed on www.wireless4mb.com. Otherwise, you'll have to experiment or keep checking this forum.
#49
There are major hardware, software, and network parameter differences indeed. Both versions however, implement Bluetooth 1.2 profile in a way that is fully functional with the MB Puck and the MHI Bluetooth Interface Module.
If you are shopping for service by choosing a phone model first, the GSM RAZR is the better mobile right now.
#50
S 430
i called my local dealer here in fort lauderdale and asked for the blue tooth cradle adapter for a 2001 S430 with the V60 phone..the part guy said they only had something for the 2007..he then gave me a number to a local audio guy that could hook something up for around $500 and all it did was use the speakers in the car...does any one have the part number that I need to hook up to my V60 cradle...thanks
