Sponsored by: Innova
Comand installed
Old Apr 29, 2006 | 04:30 AM
-X-'s Avatar
-X-
Comand installed
Hello folks, right now i`ve installed my euro comand in my 2006 C-Class but my Nav DVD isn`t working in it, could you tell me which part # i would need for the NY Area?
Greetings, Chem!
Old Apr 29, 2006 | 05:19 AM
benzmodz's Avatar
W203 slightly modified
Greetings, Chem!
Here is the problem. The map you need is a file merge of the E-Class map and some other Euro map which may boot the Navigation. Thus it is rather inconvenient unless you are familiar with the operational details of how to make this possible.
Old Apr 29, 2006 | 05:42 AM
-X-'s Avatar
-X-
Damn, and do you know how it`s possible to fix the problem?
Grettings, Chem!
Old Apr 29, 2006 | 06:05 AM
BigSis's Avatar
Former Vendor of MBWorld
Nothing MB related (sorry)
US nav. DVDs don't work in Euro spec W203, W209, W164 DVD comands... the discs need modification. But this modification is very hard - if not impossible - to achieve.
We know; we have tried it ourselves.
greetingz,
BigSis
Old Apr 29, 2006 | 06:19 AM
-X-'s Avatar
-X-
So you could help me out with an solution?
Greetings, Chem!
Old Apr 29, 2006 | 07:20 AM
benzmodz's Avatar
Greetings, Chem!
Take the C-Class Euro map DVD and take the E-Class USA DVD.
Move the files from the Euro version into a folder. Then look at the file names of the DVD from the Euro version.
There will be a bootloader application on the C-class DVD.
Move the E-class files into a different folder.
Examine the details of both folders. The file names and the file sizes are very important. The files which are the same function have a similar size and similar naming but never the same. To make that you have to do it yourself.
Now rename the E-Class FILES into the same names as the C-Class names. Do not modify the bootloader name.
Merge the files over to the C-Class folder. Copy over the top of the old Euro maps.
Dump the E-Class bootloader
Burn the combination files into a new DVD and hope that it works in the navigation. It might not ! But if the DVD is readable then it will work but have you no places of interest.
I am not aware of which USA origin disks can be used in this. All you need is an original map of some kind FOR THE EURO version and the map switch usually works fine.
Old Apr 29, 2006 | 07:24 AM
-X-'s Avatar
-X-
Thx a lot for ya help! I`ll try it and tell ya if everythings workin fine!
Greetings, Chem!
Old Apr 29, 2006 | 08:53 PM
SUNILP's Avatar
2015 E250D
even after modifying the disc, there is a 50% chance it will still not work. Must have purchased it from Euro Comands on ebay.
