Seeking COMAND pinout (pic attached)
greetingz,
Yes, the face on the W164 and the W163 are "different", but I will either make this retrofit work or die trying!
I have a jigsaw and roll of duct tape in hand, may I please have the pinouts?
Kind regards,
Buddy
Last edited by buddypetty; Jul 12, 2006 at 01:59 PM. Reason: Augmented tool requirements
I do not plan to use the steering wheel controls either (of course). Will the radio be adversely affected or operate improperly because the D2B/MOST are not being used?
Primary goals for this project in order of priority:
- Pleasant Physical appearance (this should be fun)
- FM/AM/Internal CD
- Satellite Radio (are you Sirius?)
- Internal DVD Navigation, external GPS antenna
Wannabe goals, if possible:
- Bluetooth
- Treo650 Phone Intergration
- World Peace
Is it possible to achieve the primary goals?
Sorry for the humor, just trying to keep it light,
Buddy
It looks like the connectors on the back of the A164 are different from the connectors on the back of the A163. That's why I was requesting the pinout, becuase I figured I could possibly match-up the A164 pinout with the A163 pinout that I found in one of the threads on MBWorld.
Also, the A164 I bought is used (of course) and I would like to test it before taking a blow-torch/hacksaw/dremel/ax to my dash, which is another reason that I was trying to figure out the power and speaker pins.
In all seriousness, my ML is in excellent condition and I hope to keep it that way. Any suggestions on where to find the harnesses and testing pinouts are greatly appreciated.
The unit needs to be tested before I can make a final decision whether or not I want to pursue this project.
Thanks,
Buddy
You can buy an adapter harness from mercedes if you think your jigsaw skills are good enough to give it a try...203 540 83 08
greetingz,
Thanks for providing initial direction on what seems to be a useless task.
Buddy
greetingz,
The Mecedes dealership in my area (Virginia, USA) does not see that part number as a valid part number.
I have hear of Euro parts that are not ordered by American dealers. Is part number 203 540 83 08 considered a Euro part? Do you have any suggestons on where it can be bought?
Buddy
As all US spec 203s and up come with factory installed radio - that part most probably is NOT available in the US...look for it on german ebay - it will be PLUG AND PLAY with that harness (so you can always go back easily once/when/if the install doesn't work out too well).
greetingz,
When it came down to modifying the dash, I did not want to test my hacksaw skills.
But, I do enjoy a good challenge and have begun evaluating the installation of a 2005 COMAND (A 163 820 05 79). Yes, I realize that there are probably significant wiring and fiber opitic compatibility issues.
Thanks to everyone that provided guidance,
Buddy
Buddy
Cable harness A2035408308
Converter A2118200088
These are the cables that are mentioned above needed to convert to the newer wiring
Both of these are brand new original Mercedes Benz parts. I actually had to create a BIN through my dealership to get these here beacuse they are not available to the US..the reason for sale is I have a 2005+ C-class which already has the new wiring..I ordered these by mistake
Please PM me for photos and price
Thank you All
