Sponsored by: Innova
Anyone running stock subs along with aftermarket?
Old Jul 20, 2006 | 07:03 PM
dannieboiz's Avatar
08' S550, 04' E320 4matic, 03' Acura TL-S 6 speed, 1968 Vespa P150
I'm going to put a single 12 Eclipse Alum. in the trunk and power it with an undecided up but something 600watts, PPI 2600 looks like the winner at this point.
Anyways, I already have the high to low converter, going to tap that into the current sub and do it that way. Should I disconnect the sub and remove it completely or should I just leave it? It doen't sound bad at this point but it's just part of my nature to add at least a sub.
I have a w211 with the HK Logic 7 system. Going to keep everythiing else stock.
Old Jul 20, 2006 | 07:18 PM
Torquey55's Avatar
2006 E55
Check out this current thread from the E55 forum. It may be wise for you to consult a reputable shop before adding components to the factory system. PM me if there is anything I can help you with.
https://mbworld.org/forums/w211-amg/155982-audio-system-disappointment.html
Old Jul 20, 2006 | 07:24 PM
dannieboiz's Avatar
I'm not looking to replace anything, just adding a sub. I have a DEQ 9300 that I can dedicate just to the subs. It's been collecting dust for a very long time. It's an old unit but works like a charm. The system just lack a little bass, I'm happy with everything else for now.
Old Jul 31, 2006 | 08:08 AM
ldangeli's Avatar
EFF YOU JACKIE
It can be done. If you still need info, contact me. I can point you in the right direction.
