AWS MB Bluetooth and Phone Compatibility Info
First, the BT puck information is available for various years and models at http://www.wireless4mb.com/btsolutions.aspx - there you can access more vehicle-specific information for your model year and type car. The categories plainly subdivide at model years 2005-2007, and 2002-2004.
When I entered a 2000 and 2001 S class, I got “Hold” pages for the upcoming Timeport puck. No information is available for this puck on the AWS page, but one contributor who has discussed this with AWS indicates it will be a puck with a “tail” (wire) that will connect to an existing connector in the car (e.g., in the center console for the S-class).
This is just a guess on my part, but it is likely that the BT puck for the TimePort will also work in the StarTac installations in the ’00 without replacing the PSE – but I don’t know if you’ll get caller ID with the StarTac PSE and the new BT puck. TimePort phones were essentially digital StarTacs with some additional features. However, the StarTac PSE did not provide caller I.D, and the TimePort PSE did.
Once you have gotten to the page showing the type of BT puck for your car, you can choose the “wish to purchase new phone” option and bring up the list of phones AWS is marketing. Once there, you can select the “In Car BT features” link to bring up a chart showing which features will download to COMAND, and that are accessible, for that phone. The phone compatibility charts for the MHI puck and for the V60 puck are slightly different, so be sure you're using the chart for the right puck.
It certainly doesn’t cover every phone – only those that AWS markets. However, many contributors have already provided specific information on variants of these phones. For example, AWS provided info only for the Cingular RAZR V3 (a GSM phone), and notes in the chart small print that “features like Phone Book Download, Call Lists Download are not included in the HFP Standard and can not be guaranteed with every phone.” However, Verizon users report that the RAZR V3c (a CDMA phone with OBEX crippled) does download the phone book, at least with newer versions of Verizon’s HFP firmware (users with GATW-01.15.03 and later have reported good results on downloads). A search of the forums will probably yield extensive information on specifics such as this for other non-AWS “approved” phones.
For many users, if you already have a phone such as those marketed by AWS, it is likely that the newer firmware versions from your service provider will offer similar features to those shown in the AWS compatibility chart for the type of puck available for you car.
I have a suspicion - and would love to be proven wrong - that the MB BT pucks are programmed to provide the same MB-coded "handshake" to the MHI that its branded phones supply, fooling it into thinking an MB-branded phone is present - and allowing the use of non-MB phones with the puck. If the MHI requires a "handshake" that a direct connect non-MB phone does not provide, then the MHI would shut the phone down.
You might ask a dealer if you can plug in an 815 cradle and see if your phone will work - or perhaps another contributor has the answer.
You're right about the V3m (multimedia) - but some of the older phones (such as my V3c) updated to v.04 firmware can use some of the features advertised for the V3m. The Verizon Navigation feature is one (I wrote up my experience with that earlier this month). Perhaps the HFP implementation on the V3m isn't too different, and it won't encounter problems with the MB BT. We can hope, and perhaps someone will share their experience.
However, I'm part of the Verizon V710 class action, and I have to replace it. Thinking either the RAZR so I can maintain full Bluetooth capability with the car, or the Motorola Q in hopes that either new software from Verizon and/or MB will enable full Bluetooth functionality in the near future (another thread here indicates the phone book will not download in their current versions).
A conversation with a fellow at AWS suggested that I get the Q; I assume he would only say that if it will be compatible soon...
phone book transfer
caller ID
voice activation
Comand keypad
steering wheel controls
Don't know about call waiting, 3-way calling, or text messaging
2004 S500 4-matic
- No Timeport/StarTAC Puck is planned. Although the Puck works with these 2000 and 2001 systems with a cradle and PSE swap, it's not officially approved by MBUSA.
- Puck With Tail is coming in October. It's the perfect solution only for 2003 & 2004 E-Class and 2004 S-Class cars that do not have a phone system already installed. It plugs into the cradle connector under the console floor and provides integrated Bluetooth phone functionality. No other parts are needed because only these cars were equipped with CP211 platform Teleaid control units that have cellular phone control functions already built in. (Teleaid box basically includes built in PSE).
Guess that leave lots of '00 and '01 S500 and other owners to upgrade to the Autosense PSE and V60 cradle with a V60 puck, at least in the forseeable future.
GO on Ebay and buy a v60 cradle for your 00-01 vehicle. Then the BT works perfectly...the only other thing i did eventually do was to also buy the V60 PSE, just so i could get caller ID. Both were under $100...
Both my Cingular Razr and Cingular Treo 650 work FLAWLESSLY, both download phone books, etc...
* You mention 03 and 04 E Class.. does this INCLUDE the NAV replacement cars of MY03? Or are the NAV cars excluded for some reason.
* Where is this puck with tail available from? Is it from AWS therefore an official MB backed product or is this totally aftermarket?
* Is this a DIY, simple hook up.. or will it require dealer intervention (apart from the STARDiag activation I'm sure).
* Oh, and price and still on target for October?????
Peter
