Sponsored by: Innova
upgrading timeport crade to V60 cradle
Old Aug 22, 2006 | 01:39 PM
daSong's Avatar
2001 W210 E320
has anyone upgraded their startac or timeport cradle to the V60 cradle? How much did it cost? I called my dealer and they couldn't give me a price, I'm about to call a dealer in another city soon.
I know that mikbox makes a solution but I was wondering if anyone has done it through Mercedes.
Obviously, i'm interested in gettting th V60 bluetooth puck.
I know the argos has an all in one solution but I would like to take advantage of the cradle in the armrest and I don't want to spend 800 dollars if i can help it.
Thanks for reading,
David
2001 E320
Old Aug 22, 2006 | 06:35 PM
SUHAIL's Avatar
1986 190D 2.5 (W201), 1999 SLK230 (R107), 2000 S500 , 2001 SL500, 2005 G55 Grand edition 327 of 500
I had the old Startac upgraded to a V60 last year on my 2000 S500, the process was rather simple. Took about an hour, the Phone itself was new, so was the cradel and sometihing called the linear compensator. The whole thing cost about $1500. It was done by Mr. Keith Valentine from Running Springs California. He drove a 100 miles to my house to do it and would recommend him highly.
His phone # is 909 867 6211 Cell:714 746 5930 he can certainly help you can give him a call he is really helpful
Old Aug 23, 2006 | 11:58 AM
MagicO309D's Avatar
You'll need a cradle and maybe a new PSE (you need one that is V60 compatible, they have Blue part number labels). After that, plug in the Puck and you're done. Parts at true MSRP will run about $500 to $1000 depending on if a PSE swap is needed. Labor should be an hour or less. Since you intend to use Bluetooth only, no need to upgrade compensator.
Old Aug 23, 2006 | 12:47 PM
dimit's Avatar
2010 E63
You can get a PSE and Cradle from Ebay. There is a gentleman who sells them on Ebay for $150.00. You can easily put them both in. Also you might already have the Autosensing PSE. You need to check in the trunk and see what model PSE you have. If you have any questions email me directly and I'll walk you through it. You shouldn't spend anymore than $450.00 for cradle, PSE, Bluetooth PUCK.
Old Aug 28, 2006 | 09:38 AM
V12toHybrid's Avatar
Kia Sedona
will a v60 phone kit from a 03 sl(w230) work in a 01 cl600 (w215)with timeport phone kit?
Old Aug 28, 2006 | 10:27 AM
SUNILP's Avatar
2015 E250D
Yes it will.
Old Aug 28, 2006 | 11:29 AM
Kia Sedona
Originally Posted by sunman
Yes it will.
dude, that's a fast response how about a v60 kit from 00-02 s class? i know it's a 00-02 but it says v60? i currently have the timeport handsfree but i want to upgrade to bt. the argos kit cost $800plus other stuff. if i get the v60kit for $250 and the bt puck for $350 i should be set, right?
thanks in advance
Old Aug 28, 2006 | 11:34 AM
Kia Sedona
oh, both of the kits are available, which one should i get? the 00-02 v60kit from s class or the 03-04 v60kit from sl class? i have a 2001 cl600 with timeport kit now.
Old Aug 28, 2006 | 06:38 PM
dimit's Avatar
2010 E63
They are both the same. Doesn't matter which one. But you need to make sure you have the right PSE. It will have a blue label on it.
