SL55 - external AV
Rating: Thread Rating: 2 votes, 5.00 average.
Old 11-06-2002, 07:18 AM
  #51
pauld's Avatar
sl55 2002
Thought people may find this interesting....
http://www.donnelly.com/whoweare/cor.../thefuture.asp
if they produce it with say a standard interface (USB, bluetooth etc...) it would allow all kinds of devices to hook up.
P
Old 11-06-2002, 10:54 AM
  #52
cone's Avatar
2013 SL 350, ML 350 BT
QUESTIONS ABOUT YOUR SL COMAND
Originally posted by Richard
Nightsea.
I cant remember if the SL55 TV tuner is in the rear left
side of the boot, or under one of those storage boxes (left
hand side). Your MB dealer should be able to look it up on their WIS system
Depending on when your car was manafacturered, it either has the newer NTSC compatable TV tuner, or not. (My end June 02 built SL55 has newer NTSC tuner)
If you enter TV mode, and go thru the tuning menu, you will be able to set the country, if you find USA in there (although, I dont think its called USA, it may be called North America), then you have the newer tuner.
The newer tuner has RCA jacks (Video, Audio-L, Audio-R), the earlier tuner needs some special leads that can be bought from megacomm.
"DVD" doesnt come into account yet. MB isnt yet shipping the DVD based COMAND II system
Your SL55 has COMAND 2.0. COMAND 2.5 is only in the S & CL and has the tape player (and it is 2.5 din units high). The SL (and most others) are 2.0 din units high, no tape, with different shaped fronts depending what car they are in)
The later tuner is PAL/SECAM/NTSC, the older PAL & SECAM only. What TV system do you have there if its not one of those ??
Hope that helps
Richard.
I would like to know a few things about your SL 2003 comand
Which tv format use? 4.3 or 16.9?
Is it the same comand as C class?
When you are driving, if you press "map" on Comamd system without entering an adress before, what do you see on the screen?
R
Old 11-09-2002, 07:10 AM
  #53
cone's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: Re: ...I HAVE A 2003 S CLASS FACE LIFT
Originally posted by cone
Richard:
This saturday, 9th Nov, my dealer will change interlocks as you told me. He has star diagnosis 5/2002 software, and he is going to install it for me. Is this soft ok?
thanks
I was in my MB dealer all the morning, he couldn´t install 5/2002 sofware in the Stardiagnosis because appears an error message, called, error 150, when set up is at 19%. Do you know how to do it?
Old 11-09-2002, 11:05 AM
  #54
Richard's Avatar
2004 SL55, 2015 A250d, 2016 GLC250d
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: ...I HAVE A 2003 S CLASS FACE LIFT
No, sadly not, I know my dealer managed to install it without hastle though ...
R
Old 11-09-2002, 11:06 AM
  #55
Richard's Avatar
Re: QUESTIONS ABOUT YOUR SL COMAND
Its 4:3, same as a C class (different part number though)
Pressing map (whenever) gives you the map of where you are
Cheers
R
Old 11-09-2002, 12:45 PM
  #56
London Lad's Avatar
SL55
Richard, did you get my P.M. ?
Graham.
Old 11-15-2002, 12:43 PM
  #57
cone's Avatar
They get 2 * CD, or 1 * DVD once a month(ish) and just load it into their IBM laptop which has some special hardware attached to it.
If you cant find a dealer with Star, then you could do what nightsea is doing (see earlier in this thread I think), which is to find someone who knows Linux, download my Linux diagnostic software, buy an PC->ISO interface and connect it to the car. I'll then tell you the comands you need to type into my s/w to get those values changed to the right ones.
(remembering that the COMAND unit is on a special pin of the diagnostic connector, so get some extra pins for the connector)
Cheers
R
Richard, I have a lot of problems with upgrade Stardiag to 5/02 in my MB dealer. I will buy as Night Sea all the components for do it in a Linux computer. Can you tell me all the steps for do it?
Again, thanks a lot
Old 11-15-2002, 05:03 PM
  #58
Richard's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: ...I HAVE A 2003 S CLASS FACE LIFT
Again, thanks a lot
Ok, go see freediag.sourceforge.net - purchase the "Andy Whittaker" interface, and then work out how to download the latest CVS tree from freediag project.
You will need to get Andy to send you a cable and some extra pins so that you can connect the diagnostic interface to pin13 of the diagnostic connector on the car.
Once you have done that, I will let you know what to do.
R
  #59
Richard's Avatar
Re: Richard, did you get my P.M. ?
Graham.
Yes. I responded. And then responded again a day or so ago when I saw this message
Old 11-16-2002, 06:48 AM
  #60
London Lad's Avatar
SL55
Thanks, I got your second responce but not the first. I have replied. Thanks again.
Graham
Old 11-17-2002, 04:11 PM
  #61
Moser's Avatar
C320
Richard and Ted both referred me to Braybrook's, who installed the Alpine dvd changer to my MB tuner / COMAND. They disabled the interlocks using the old Star Diagnostics.
Neil told me at the time that I'd probably be the last one he could disable and he needed to come up with another solution. I guess he hasn't done so yet...
I guess somebody needs to get the old software and find a dealer/ tech who is preapred to re-install it to program a specific car.....
Is there any way we can purchase the hardware/ software for the STAR diagnostics, or is that too expensive an option?
I'm thinking about upgrading to a C32 AMG, but I'd want to disable the tv/dvd etc.
Also, are there plans for COMAND II to appear on the C Class??
Old 11-17-2002, 04:23 PM
  #62
Moser's Avatar
C320
Richard
Is there any way of getting a Window's based version of your Linux software.
Would make this a probable solution for those of us who are able to install the COMAND +/- DVD and want to switch off the Interlocks?......
Old 11-17-2002, 05:09 PM
  #63
Richard's Avatar
Originally posted by Moser
Richard
Ive released the software as freely redistributable in source code form - there are people out there considering porting it to windows - lets hope someone does.
I wrote it on Unix primarily because I know how to program in Unix better that Windows ..
At the next UK get-to-gether, I'll bring my laptop and tell people what to type on it :-)
R
Old 11-18-2002, 07:00 AM
  #64
cone's Avatar
R
Richard, today I ordered OBDII and connector with extra pins. In a few days i will receive my order. Now, I need you show me how to do it.
Old 11-18-2002, 07:04 AM
  #65
Richard's Avatar
Cone, PM me your email address
R
Old 11-18-2002, 07:19 AM
  #66
cone's Avatar
R
Richard, I send you a private msg.
thx
Old 11-25-2002, 03:58 PM
  #67
merlin's Avatar
E55
R
Richard, I followed with interest your statements. I will get a E55 (W211) soon and have therefore the same problem. I have already the connector and an interface. With Linux I am not unexperienced, but I have no clue what do do next !
Therefore I kindly ask you to include me into your circle of students. Can I get your software and advice too ?
regards
Robert
Old 12-30-2002, 08:19 PM
  #68
NightSea's Avatar
S600L/SL55
Angry Andy Whittaker's interface
Richard and cone, Happy New Year!
As I told already , I got the fully compiled program on Linux.
Compiled file name is SCAN TOOL.
When it is executed, Help massage is appeared.
The screen shows:
Help code Scantool version 0.2
Type Help for a list of commands
Type scan to start ODBII Scan
2. Last October , I ordered Andy Whittaker's OBD II ISO interface(ready made) plus OBD II connector with extra pins. At that time,
I paid , of course. But still not yet delivered. Already 2 months
past. And Andy Whittaker does not send any reply yet.
cone; Did you receive it?
Old 12-31-2002, 07:04 AM
  #69
Richard's Avatar
Hi Nightsea
Sounds like you have succesfully compiled the program.
Now, what I need you to do is the following :-
Select AUX input (press SYS key, select AUX)
Hold down MUTE, 1, 3 keys all together for 10 seconds
- a hidden menu will appear
Select "configuration", and tell me the 6 digits that appear at the
bottom of the screen (something like 20 CD 04) after the CFG text.
If you PM me the information, with your email address, i'll send you some instructions as to what to type into freediag to change the configuration !
As to the W211 - the technology is completely different, and I know nothing about it yet .. (until I buy a W211 and play with it, which will be a few years!)
Drop Andy a note, he is usually very quick at sending stuff out !
Cheers
Richard
Old 12-31-2002, 07:28 AM
  #70
cone's Avatar
Re: Andy Whittaker's interface
The screen shows:
Hi Nightsea:
I received 2 OBDII interface with 2 connectors. I you want, I can send you one of mine. We have some problems with linux and until now, I couldn´t disable interlocks yet.
Old 12-31-2002, 08:11 AM
  #71
Richard's Avatar
Re: Re: Andy Whittaker's interface
Hi Nightsea:
Cone, did U get my email ? Id like you to get a basic SCAN of your car done before you send away either of the interfaces !! Then we know your interface works talking to the engine management system in your car, and we can then change the pin to talk to the COMAND unit and reprogram that
Cheers
R
Old 01-04-2003, 01:01 PM
  #72
cone's Avatar
70 replies / 1592 views on SL-55 external av
Richard, Nightsea and all the people interested in this theme, Happy new year! As you can see, external av, is one of most viewed thread. I wonder why...
Old 01-06-2003, 07:31 AM
  #73
NightSea's Avatar
S600L/SL55
Richard & cone
Richard;
Tomorrow , I will send you PM ( cfg number and my e-mail address). Because of snow I left my SL55 at another place
from mine on last week. Tomorrow I will pick it up.
I received a reply from Andy , and he promised that
if the stuff is not delivered by this week ,he will send it
to me again with registered.
cone;
Thanks for your kindness. Let's follow our teacher's
instruction. If I have a problem with Andy's stuff,
then I will ask your help.
Do you have a problem with compiling job?
( I don't know anything about Linux. My man
did that job for me. ) May be I can make a copy or
send the file by e-mail ...? If you need a help,
pls let me know.
Old 01-06-2003, 07:51 AM
  #74
cone's Avatar
Re: Richard & cone
Richard;
cone;
pls let me know.
Night Sea:
Please, send me a copy by mail, let me remember you, if you need the Andy W. interface, i cand send you one of mine
I am very interested to know how to disable interlocks in your SL because I´m thinking to buy a SL 350.
Richard:
As you are a Linux expert, I would like to know if it is possible to =
disable tv interlocks with a linux pda, plugged to the Andy W. serial interface.
Old 01-06-2003, 10:45 AM
  #75
Richard's Avatar
Re: Re: Richard & cone
Richard:
Hi, if the PDA has a real serial port, (and assuming you have a compiler for it), you should be able to do this. Do you mean the Sharp Zarus (sp?) - I keep on meaning to buy one of these and try - apparently there is a new one out
R
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
Quick Reply: SL55 - external AV
