DENSION GATEWAY 500 for MOST – MENUS in COMAND
Old 10-26-2007, 10:16 AM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
If anyone has made it through all of this, I went ahead and wrote up a more detailed description of the menus for the GW 500 MOST unit working with COMAND - it's at https://mbworld.org/forums/showthrea...51#post2471051
Old 09-10-2008, 10:15 AM
praveen's Avatar
mercedes E220cdi W211
Audio20+Dension
Anyone used a GW500 with audio20(MOST)? Really need to know if there are any bugs before i buy. I can only find Comand users. Thanks
Old 09-10-2008, 10:19 PM
Skylaw's Avatar
praveen, there is probably no need to post this in at least 3 different threads on the same forum (especially very old ones). I responded to this once already. For benefit of others -
"praveen, I believe I have suggested to you before that you check the Dension website. There is a compatibility chart on the site that will tell you which Gateway 500 unit goes with which model year car, and has comments concerning incompatibilities. I believe you will find the unit works with the Audio 20, but you will not have song title readout on either your instrument cluster or the Audio 20. The writeup I gave you before at http://www.benzworld.org/forums/audi...st2376586.html deals principally with MOST units, but contains information about the D2B units as well."
Old 10-28-2008, 11:56 PM
praveen's Avatar
hi Skylaw
Your link http://www.benzworld.org/forums/audi...st2376586.html doesnt seem to be working. Is there any way you can message the info to me or do you have another link? Thanks
Old 10-29-2008, 12:04 AM
Skylaw's Avatar
Thanks for your note, praveen. It's now http://www.benzworld.org/forums/audi...ady-prime.html - also, the download page for the owner's manual and installation guide have moved to http://www.dension.com/download_icelink.html - you can also get to it from the Dension home page, http://www.dension.com/main.htm - follow the Support tab.
Quick Reply: DENSION GATEWAY 500 for MOST – MENUS in COMAND
