Sponsored by: Innova
CD-charger
Old Sep 7, 2007 | 01:15 PM
joafog's Avatar
ML 280CDI
CD-charger
Hallo!
I have a new MB ML320CDI with CD-charger! When i press CDC nothing happens!!?? I cannot put in a CD, is it a CD there already? Why does it not play this CD? How do I eject CD´s from the CD-charger?
//Joacim
Old Sep 7, 2007 | 03:20 PM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
I'd start by reading the owner's manual. It should tell you where the CD changer is (so one does not become confused with the nav disc player), were the eject button is for an individual disc (if that's what you have), and where the eject button is for the CD changer cartridge.
Old Sep 8, 2007 | 02:38 AM
joafog's Avatar
ML 280CDI
CD-charger
Good answer, but there is nothing about the charger in the manual, only where it is!!??
//Jocke
Old Sep 8, 2007 | 03:43 AM
rob13572468's Avatar
PREMIUM SPONSOR
ML350, Lotus Elise
//Jocke
sounds like the changer is either disconnected or damaged. i would take it in to the dealer. you should at least be able to press one of the disc buttons and hear movement as it prepares to load a CD. if not then its not working properly.
Diesel Benz's Avatar
//Jocke
In Europe, the radio and CDC are often on a separate user guide. I guess because we have a range of options from very simple ones to Comand.
Old Sep 8, 2007 | 04:36 PM
Skylaw's Avatar
Ohhhh, boy - the old "sort through multiple books to find partial answers in each and try to figure the system out" approach that MB seems to like so much. Just tried to help someone in the U.S. through a simple setting of time in the instrument cluster - another simple thing requiring reference to two manuals because neither covers it fully.
Joafog, if i knew the answer straightaway, I'd tell you. I'm not familiar with the European systems (or even all of the U.S. systems) - but would have to go to the manuals for location and operation (and to be sure, among other things, that the CD slot you're trying to use isn't for the nav system - a mistake that has sometimes been made by other forum members).
I hope you can find the manual for your CD system - or that someone who has the same one can help you.
