Argos Question (Phone Compatibility)
I sent an email to both distributors and haven't received anything back... and I've also searched every MB forum I'm on with no luck.
Also, can anyone comment on Blackberry integration? I might be willing to jump to the darkside if it has more complete integration.
Thanks in advance.
I'd say ask them about returning policy first, it u can return it, then give it a try.
My contacts are on memory card of the phone, not the actual SIM card (to my knowledge atleast, I've had to swap phones and re sync my contacts).
You're totally right that voice dialing would ensure easier dialing capabilities, but I'd still like the name to show up on caller ID.... otherwise it's useless for incoming calls (I know my own number and that's about it).
Does anyone here have the Argos and a WM6.0 phone?
The basic phone functionality works fine. It pairs up, and it uses the car's micropone, speakers, and head unit buttons. I don't have steering wheel controls.
It does not load the contacts list from the phone into the Argos. (In my case, that is just as well, as I have 1000+ contacts). What it does do is load the "phone number" for the voice recognition function in the phone into the Argos. So, I can select that number from the head unit keypad, hit "send", and then hear over the car's speakers the voice recognition prompt from my phone. I then can say "dial Home" and it will call my contact named "Home".
I've been very happy with it.
If you have any other questions, ask away!
- Frank
Do you not have steering wheel controls, or do you not have access to use them with the Argos? I've got steering wheel controls and it'd be ideal to use them...
If anyone can share their experiences with the Argos and a Blackberry, that would be appreciated.
On caller ID, you are right - only the number shows up on the head unit display. I guess you could make use of the distinctive ring per contact feature of the phone to help distinguish who is calling, but that doesn't help with hundreds of contacts, I know.
- Frank
