Sponsored by: Innova
installing aftermarket stereo, need instructions for E Class w210
Old Dec 11, 2002 | 02:51 PM
btx's Avatar
btx
Does anyone have picture instructions on how to remove the OEM stereo from 1996-99 E Class
Old Dec 11, 2002 | 07:02 PM
mmgrad's Avatar
W213 '17 E43 ///AMG - W211, W208 no more
i believe, if the stereo is the same as the 98-02 CLK, there is a CD-Key you buy. stick it in the slot, and you pull the stereo right out. Very easy.
Just check for the two slotted holes on the bottom 2 corners.
Old Dec 11, 2002 | 07:03 PM
mmgrad's Avatar
by the way, if that key is what you need, I have a set for sale, still new.
PM or email me if that is what you need.
Old Dec 12, 2002 | 12:50 PM
btx's Avatar
btx
hmmmm, didn't know that.....i will check if there are any slotted holes
Old Dec 15, 2002 | 12:02 PM
btx's Avatar
btx
Yes, my stereo does have the 2 slots. I cant believe its that easy to remove it. Is this all I need to remove to install an aftermarket stereo? Does anyone sell adapters to connect to aftermarket stereo?
Old Dec 15, 2002 | 04:49 PM
potatobbq's Avatar
I just recently had an audio shop replace the W210 stock head unit with an Alpine head unit and they used a harness to connect it to the stock wiring but I was told there was an external amp that the had to rewire to get the head unit to work correctly with the stock speakers. I'm sure you can get a harness from any stereo shop. They also said I needed an adapter for the antenna connector so you might want to look into getting that also.
Old Dec 16, 2002 | 01:08 AM
mmgrad's Avatar
Yes, it is that easy to remove the head unit. The keys make it real simple.
As for harnesses, I'm not sure about the antenna, but I belive a VW stereo harness is the same and compatible with MB.
As for the amp, i'm not sure about the old models, but if it uses a digital amp, I'm not sure if you can do it. If you have a non-digital amp, then it might be easy.
Not too sure about this subject. However, I would suggest just using an aftermarket amp to run the headunit. Much cleaner sound, better output overall.
Old Aug 30, 2004 | 08:44 PM
benzman's Avatar
1995 C36 AMG
Do you have any additional information about this? Theres not a single harness i can find premade.
Old Aug 30, 2004 | 09:15 PM
sura's Avatar
1996 S 420
You can find instructions with pictures on radio removal at this url:
www.perfectmarketaudio.com
Harnesses are kind of tough, not knowing what kind of radio you want to install...
Old Aug 30, 2004 | 11:43 PM
benzman's Avatar
1995 C36 AMG
Radio removal was cake work, now I just need to know if the vw harness and antenna converter works before buying, then about running the additional wire from an accessory and ill have the basics done.
Old Sep 8, 2004 | 06:13 AM
benzman's Avatar
1995 C36 AMG
Found a harness premade on ebay, even comes with detailed wiring guide. Attempting to install today.
Old Sep 13, 2004 | 01:18 AM
figure1a's Avatar
2000 E320
You can use the VW harness. There are a couple of them so the easiest way to be sure is to pull your stock stereo out and make note of the connectors and how they look. Then match up the VW connector that will do the trick.
The only thing you'll need to custom wire is a remote turn on lead. I usually tap into the cigarette lighter postive terminal as that only gets power when the car is on.
