How do I remove equipment tray (phone install)
I'm trying to remove the equipment tray that is located in the trunk (directly behind the rear seat). I'm considering installing a phone and know that I'll need to remove the tray so that I can mount the phone modules to it.
I've removed the two (2) screws that are located at the front of the tray; however, I can't seem to get the rear clips to release.
Does anyone have a diagram of the equipment tray that shows the locations of the screws/clips which need to be removed? Or, can someone list the steps for removing the tray (without the use of a prybar)?
Thanks.
Surely someone knows an easy way to remove the equipment tray. The telephone installation intructions (P-I-82.70/405A) refer to this piece as the carrier plate.
Regardless of what it is called, I can't figure out how to detach the top piece from the bottom piece.
Please help.
Thanks.
Why do I need to do this, you ask? Because the carrier plate is where a lot of my telephone (fiber) cables and connectors are located, and where I need to mount the MHI control module and VCS module (once I purchase them). So basically, in order to mount the new modules and to make the connections, I have to remove the top piece of the carrier plate.
I have removed two screws from the carrier plate but I cannot get the clips that are closest to the rear seat to release. I am able to peer between the top and bottom pieces with a flashlight and can see all of the cables and mounting locations. Very frustrating that I cannot get the pieces to seperate.
I don't remember if it came off easily when I last time accessed this space but it really should come off once the two screws have been removed. I believe you can just carefully pry it off.
I've tried pulling, prying, yanking, sliding, squeezing, cursing and banging...all to no avail. It seems like the rear center clip is the one that does not want to release. It's hard to tell, but it seems as if there is another screw that I can't see or access. Any ideas?
Actually first run this tool alongside the seems, and press deep (downward). Run it on all sides. Then try to pry it up.
The upper tray is really tricky. To remove the top (cover) there are 2 "hingles" which you would have to press inward (sort of like changing the toilet tissue roll). You have to unscrew the scew from the "tray" of top level. Then slide it outward. Then After prying the place holder of the phone cradle (the cover plate) you can see the cables underneath the tray going toward the back of the center console box.
