How To Disable DRL
I was wondering how to disable DRL for an 04 e55.
I have tried on the steering column under lighting, but it didn't work. I also search and someone said I can change this in the Command menu?
Or do I have to take it to the dealer?
http://www.ibiblio.org/rdu/DRLs/studies.htm
You change it from "Constant" to "Manual." If that option is not available, your cluster is coded for a different country and assumes DRL is mandatory.
1. Legal reasons.
2. Most probably do not know how, assuming it's even possible.
You would be better off asking someone independent shop with an SDS to do it.
That's not what these lights are--they are parking lights, which have always been on with headlights on cars sold in the USA since I think 1963.
It's a silly idea. Sorry you care more about how you worry your car looks to others than you apparently care about function. The "function" in this case is to provide a spatial indicator should the headlight be burned out on one side.
