Kenwood DNX8120 in a 2005 C230
I'm looking into putting a Kenwood DNX8120 into my 05 C230 but I just have a few questions. Hopefully someone who has done this before or someone who just knows can help me out.
1. Can i use the stock amp to run the speakers or do i have to bypass and run the unit directly to the speakers? I went to 4 different shops in my area, two said i had to bypass, one didn't know and the other said i could use it.
2. Do you know the parts/numbers to keep the steering controls. Ive searched the PAC swi-can website for the module, but they don't list one for the 05 c230??
Thanks in advance.
2] take a look at http://www.connects2.com/ - they are pretty popular over here, I'd imagine you can get them stateside as well.
website just says 02-04 or w203 with similar plugs???
Thanks...
I have a Kenwood DNX7100 and I connected it to my factory speakers in a Volvo and then added a kicker Amp and Sub. The results were fantastic, when I crank it the mirrors shake so much and I cant tell what kind of car is behind me (not that I care). I just bought a 2007 E-350 and will purchase another Kenwood (the latest and greates) and do the same again. So I highly recomend leaving the factory speakers and just connect a matched amp and sub. You will be very happy. If you live in MA I will show what can be accomplished allbeit in a volvo S80. The 350 will get the same once I figure out what is needed.
https://mbworld.org/forums/cls55-amg...-ipod-fix.html
I had my DNX8120 installed this past weekend. I had it done at Gold Star Audio in Irvine. I really want to hook up the steering controls. They told me that there are no modules that work with the 2005 C230K as of right now. Some other shops have told me that it is possible?? Has anyone ever done this before or heard of anyone doing it with the 05 w203??? and what modules were used??
Thanks!
i asked the stereo shops about the pac-swi jack & the pac-swi can, but they said it doesn't work with the 05 w203's... On the pac site it says it only works on 04 and older w203's, but other shops told me it would work and others didnt know.... maybe ill call PAC and ask them..
anyone here with an 05 w203 that has used steering controls with an aftermarket head unit???? anyone seen it done??
http://www.benzworld.org/forums/audi...g-rse2-my.html
Thanks!
What did you do about powering the the speakers? Did you add an amp or did just drive four speakers? I am thinking I am going to put the same stereo in my E350.
By the way stereo looks slick how do you like the unit?
I'm using the power from the head unit. My car didn't have an external amp or a sub. So basically the wiring harness was plug and play as much as i know. I didn't do the install so i'm not 100% sure. but they did tell me it was a straight up install. So i'm just running the speakers i was using with the factory head unit. This HU makes it sound a lot better...
i recommend this thing 100%
