Sponsored by: Innova
no radio after changing battery
Old Jun 5, 2011 | 10:02 PM
Cycopath's Avatar
2003 CLK55 AMG
2003 CLK 55
i had a dead battery, jumped it, got to the auto store, had the battery tested and found it to be bad. got a new one, installed it. great, car starts right up and i drive off. then i go to turn the radio back on and NOTHING. it won't turn on at all. on the COMAND unit, when you switch to the audio section, it would normally say "Audio Off," but now it just says "AUDIO ------"
i checked to make sure the fuse wasnt blown and it appears good. swapped it for another fuse just to make sure, and nothing. i guess, the next option is taking out the radio and checking to see if its even getting power.
i did read on the fuse diagram to follow the Owners Manual instructions for radio issues, but i searched up and down and found no instructions. am i missing something? do i need to reset it somehow?
Old Jun 6, 2011 | 01:25 PM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
Try disconnecting the battery (again) for about 5 minutes, then reconnect.
Your COMAND unit does not use a radio code, so that is not the problem.
Old Jun 7, 2011 | 02:39 PM
Cycopath's Avatar
2003 CLK55 AMG
i will try the battery thing.
if not, does anyone have instructions to remove the radio? i can see if its even getting power that far and go from there
Old Jun 8, 2011 | 08:28 AM
Skylaw's Avatar
Try http://www.carstereohelp.com/strmercedes.htm - there are removal instructions for many radios on the page. If not for your car, a Google search may get you more.
