Passpport 9500 ci GPS Antenna Placement
It will not get a lock inside the car as the CL and S Class has metal foil IR glass. You will notice your iPhone or other handheld GPS has a hard time too (it get it from the sunroof or side windows - which are not IR glass)
Your installer should know this, but most importantly should not have placed an antenna visible anywhere inside the car. It takes very little effort to hide them in rear view side mirror, rear decks, bumper covers, etc. That is simply embarrassing (to them) and our profession.
They don't use K band for the very reason that people can use distronic as a defense of a bad reading, along with door openers etc.
First, according to Mid City (the owner), approximately 90% of K band is left intact with its module. I cannot tell either way. If he is correct, it would make sense to keep it. If not, then I see no huge advantage to the module and some downsides as well. I now need to research just how much K band is actually used in my area (New York--East Coast) to see whether shutting it off is leaving me unprotected. Is there a website for this info?
Second, I cannot split the module to also leave the original display intact. That would have been my preference.
Third, the mute button will continue to flash on the controller (quite visibly at night) as the controller is continually picking up K band from the distronic plus, but not passing it on to the cluster. Most annoying.
As for the 9500--I really need to get rid of the two beeps that come up when I pass a stored location which has only become stored due to the auto learn function. I am reluctant to turn auto learn off for reasons I cannot articulate other than I assume default settings are there for a reason. I also find the red light camera warnings to be helpful but I also wish I had a choice to keep the visual (but not audible) warning intact for them. I understand from Escort that my only option is to have both warnings or no warnings.
All in all, I am hoping that tweaking the settings on the 9500 will resolve most of these issues and that the module does what it says. If I knew that K band was not an issue in my area, I think I would ditch the module.
I drive extensively through Georgia, Tenn, Florida, Alabama, Louisiana, Missouri, SC, NC - and I can not remember the last time I heard K Band go off from an officer. It has probably been 6-8 years ago. The only thing that still runs K band that I am aware of are the automated "this is your speed" signs, and the construction signs that light up as you approach on the highway.
Mid City Engineering
pros - supposed to filter out distronic plus so K band can stay on
cluster display (albeit supplying limited information)
cons - must leave in audio mode to see display
lose satellite icon so can't tell whether locked on or even working
lose any ability to display speed on display
lose real ability to use autolearn
steering wheel controls very limited
So, assuming someone has not found a more elegant and practical solution to a distronic plus car (including a different radar detector that would avoid these problems), it appears as if the choice is accept the limitations of the Mid City cluster of simply turn K band off on the 9500CI and keep all of its other functions and original display. Any opinions on this choice are most welcomed. Also, does anyone know how often the distronic plus puts out a signal? With autolearn off--it appears as if the mute button is no longer flashing all of the time (as it should and was when autolearn was on as if it is picking up distronic plus).
So--K band off vs. Mid City cluster. My location is New York. Thanks for all of the help.
First off, the only reason you are getting 1/2 the GPS signal where you placed it is due to the govt, providing many GPS satellites.
jlr for optimal, and I mean optimal performance, the drivers side hood vent (on top of the hood drivers side) you can mount the bracket that comes with the GPS antenna in the 9500ci to a tab that protrudes out, placing the antenna on it and it is 3mm from the mesh, providing a perfect location. you can then run the wires with the factory nozzle tube on the drivers side hinge, which will keep it from getting pinched. To access this location you have to open the hood, remove the basin from under the vents... takes 15-20 minutes for the inexperienced couple of torx and plastic nuts.
The mirror thing isn't that great, especially because it is hard to see in the day light...
K band is huge, as many many many police departments still use it. with the mid city interface you have a chance, turning the band off is just foolish. you will be driving unprotected, and the radar detector will become a liability because you wont have faith in it. I have tested almost every installation with the local law enforcement guys which have k, ka, and laser guns.
I am not trying to sell you anything.. just pointing out the facts. mirror is worthless, even the cluster display is worthless but the cluster display is clearer and easy to read unlike the mirror... however the speaker telling you that the threat is ahead... and your not looking down at a cluster to figure out what the detector said... or trying to read the mirror and decipher what the hell it says during the daytime...is the best
I honestly cant believe you said that... E gads
