Replacing the COMAND just got easier
Old 01-29-2014, 09:36 PM
  #101
jbondox's Avatar
beater with a heater
Doug, no idea
Sethro, no need for it, speaker wires are behind the radio, no optical amp.
Homie, no it wont
Old 02-05-2014, 12:31 AM
  #102
ilovemaui1's Avatar
1992 500E, 1994 E500, 2011 E550 and 2018 GLE350
I checked into the OPT1 for my 2003 SL500 about six months ago and was told it would not work. Has the system been updated to allow changing the head unit and keeping the rest of the system intact? The 2003 Nav unit is pretty much useless. I can reach my destination quicker than I can program the destination.
Old 02-05-2014, 08:11 PM
  #103
jbondox's Avatar
if it is D2B then no. it is a different optical set up. after 03 along came MOST optical (for that vehicle) slim chance if it was built after October though.
Old 02-05-2014, 08:13 PM
  #104
jbondox's Avatar
Also I just want to say AutoToys does not have these period! so if they say they do, they are lying through their teeth as some unlucky member here found out. though they took his money in a heart beat.
Old 02-05-2014, 09:16 PM
  #105
ilovemaui1's Avatar
April 2003 for mine.
Old 02-07-2014, 09:06 PM
  #106
jbondox's Avatar
Sorry, wont work. You will need to add an amp, 5 channel minimal, and rewire the speakers.
Old 03-02-2014, 12:50 AM
  #107
jbondox's Avatar
3000 emails later
it works for...
2005-2008 CLS
2003-2008 E
2004-2006 S
2004-2006 CL
2005-2008 SL
2005-2008 SLK
if your vehicle doesn't fall in the above list, there is nothing more I can do, Sorry!
2sl0w (07-17-2020)
Old 05-16-2014, 03:56 PM
  #108
jdh34's Avatar
2007 GL450
Originally Posted by jbondox
no it will not work for that vehicle, version 2, due out the end of the year will.
Is version 2 also supposed to work on a 2007 GL450?
Old 05-17-2014, 12:44 AM
  #109
a100steaksauce's Avatar
W218
Subscription
Link please
Old 05-17-2014, 07:47 PM
  #110
jbondox's Avatar
it will, I will check the status or email derek@navtv.com he's the man spearheading the project but is also running navtv, soooo. I am sure he is extremely busy.
Old 10-27-2014, 07:48 PM
  #111
hoggertp's Avatar
2004 CL500
Upgrading Audio/Nav/BT Etc W215 2004 CL500
Hello everyone, I am new to this forum. I have a 2004 CL500 and I am looking to upgrade the current COMAND HU with an Alpine HU. Wish to retain the Bose amp and the speakers but feel the balance of the equipment is redundant. Looking for information specific to my vehicle to assist me in the installation. I have read through this forum and just looking for a little guidance to assist me.
Equipment I have:
Alpine INE w957HD
NAV-TV MOST HUR-MB
Axxess ASWC-1
VMA3B-antenna adapter--with both a 12' and 8' antenna extensions
VTK230 HD backup camera
I would like to do a little prep work and then have a professional installer tie in the HU with the steering wheel controls and the NAV-TV module.
Assume I need to retain the following in the MOST loop: Amp-AGM-TeleAid module (unless I bypass and get vehicle recoded). Is there any other component in the MOST loop that is a must keep. NAV and cd disc changer to be bypassed and physically removed.
I will be removing the Motorola phone system (cradle and wires/cable, etc.) from the center console upper arm rest compartment and running the USB connector there for IPOD and flash drive connectivity. Also, running the cables to set up the microphone for the blue tooth and the GPS module for the Navigation.
Is there a good place in the trunk area to connect a 12V line and ground for the backup camera? Can run the connections under the trunk lid cover and then the RCA cable under back seat towards the front center console.
Finally, is the silver amp (has fins for cooling perhaps) looking thing attached to the drivers side rear wheel well with an antenna and power connection for the phone or is it for the radio? If it for the phone, where is the antenna connection located for the radio?
Any suggestions or guidance would be greatly appreciated.
Thanks.
Terry
Old 11-07-2014, 09:55 PM
  #112
jbondox's Avatar
sorry on vacation, did you get it? you should run the camera wires with power and ground back up front to the radio as it will make troubleshooting later easier if there is a problem. antenna should go to the audio gateway
Old 11-10-2014, 06:56 AM
  #113
csking66's Avatar
1999 E320 4MATIC
E550 HU update
I've been looking for 2009 E550 so I could get the latest version of Comand for the W211. Will this work for a 2007 or 2008 E550? If so, how do I get one? I already have a two month old Kenwood and would like to use it; however, I didn't realize I could use it.
Help...
Stacey King
Old 11-10-2014, 10:44 PM
  #114
jbondox's Avatar
either system will work
Old 03-23-2015, 10:22 PM
  #115
tgee's Avatar
1998 clk320
Back up Camera
Where would be a good place to hook up the power and gnd for the camera that is close to the HU?
Thank You.
Old 03-23-2015, 10:27 PM
  #116
tgee's Avatar
1998 clk320
Antenna Connection at AGW
Is the antenna of the car connected to the AGW now? Do I unplug it from the AGW and connect it to the Antenna adapter?
Thank You again.!
Old 03-24-2015, 10:39 AM
  #117
Launchstation's Avatar
2016 GLE450 AMG Coupe
Thank You.
The cigarette lighter wires are gonna be your best bet. Just remember that the ground wire on German automobiles is (brown) and NOT (black). Hope this helps.
Old 03-26-2015, 12:51 AM
  #118
jbondox's Avatar
Thank You.
cig lighter
Old 03-26-2015, 12:52 AM
  #119
jbondox's Avatar
Thank You again.!
on an e class yes
Old 03-26-2015, 07:26 AM
  #120
tgee's Avatar
1998 clk320
06 sl500
Old 03-26-2015, 07:47 AM
  #121
jbondox's Avatar
yes at agw, drivers side, aft of the drivers door behind the panel
Old 05-01-2015, 12:36 PM
  #122
SLSL55AMG's Avatar
SL55 AMG
So how much should a shop charge for a job on an '07 SL55? Shop I went to didn't know about this, so any suggestions as to who I could go to around NJ/NY would help as well.
Old 05-01-2015, 02:20 PM
  #123
tgee's Avatar
1998 clk320
Don't know how much a shop should charge. I did it myself.
I live in Canada. Don't know anything about NJ/ny. Sorry.
Shouldn't take a professional more than 2-3hrs. Not a complicated job for them.
Old 05-01-2015, 10:27 PM
  #124
jbondox's Avatar
About 3 hours for a shop, I did so many I can knock em out in about an hour but I have done many and know every short cut there is when running the wires to the AGW
Old 05-02-2015, 12:12 AM
  #125
tgee's Avatar
1998 clk320
Hey Jim,
You know I have this "hiss" when I turn down the volume. If I installed the steering wheel control, ASWC-1, and turned the volume down there, do you think I can get rid of the "hiss"?
Thanks.
Quick Reply: Replacing the COMAND just got easier
