Sponsored by: Innova
Best Location For Sat Antenna!
Old May 23, 2004 | 09:30 PM
tipnrip's Avatar
e500 4m
I MOUNTED SAT ANTENNA ON REAR DECK LID BEHIND CENTER HEAD REST INSIDE CAR FOR BEST RECEPTION. i HAD IT UNDER THE REAR DECK AND THE RECEPTION WAS POOR
Old May 24, 2004 | 07:29 AM
Eddie Knopp's Avatar
2013 E 350, 2012 GLK 350, 2012 C300 4matic
What car do you have ? Others have reported very good results (t-bone) under the deck lid in an W211
Old May 24, 2004 | 03:53 PM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
I hope you guys are referring to hat tray, parcel shelf, rear deck, etc. (I suppose the first poster is because it was mounted "inside").
Deck lid = trunk... under the deck lid would indeed give very poor reception.
-s-
Old May 25, 2004 | 08:48 AM
corgiman's Avatar
E55
I have the antenna under the rear parcel shelf on my W211 with excellent reception. If the phone works so does the satellite.
Old May 25, 2004 | 02:13 PM
ctemkin's Avatar
2003 E500
I have an XM antenna on top of the shelf behind the right rear headrest. It is totally unobtrusive; it does not catch your eye at all from inside or outside the car. Reception is fine. I get occasional drop-outs, but so did I in another car with an XM antenna on the roof.
Good luck on getting your set-up to work. Satellite radio is great.
Old May 26, 2004 | 07:46 PM
davidasman's Avatar
2002 C230 Kompressor
both my sirius and comand antennas are mounted under the dash behind the instrument cluster of my w203. totally hidden. in the 8 months w/ comand and 5 with sirius i've never had any problems whatsoever.
Old May 27, 2004 | 02:53 AM
airbusman's Avatar
2004 E320 4matic Euro Delivery / 2001 ML320 / 2000 A170cdi
Antenna mounting
I would follow the factory instructions (Star Bulletin) - anything else (Sirius radio with factory warranty) is not covered under warranty.
Ed
Old May 27, 2004 | 10:48 AM
BlueMonk's Avatar
I had mine installed Tuesday under the rear deck in the corner on the passenger side. Reception has been as good as I have experienced in other setups with Sat radio. Will get some cutouts if I get trapped under an overpass. Otherwise reception is flawless in my short test.
