Sponsored by: Innova
How to keep sub box from moving in trunk?
Old Jul 2, 2004 | 12:46 AM
kyee's Avatar
Question How to keep sub box from moving in trunk?
I have a JL Audio sub box installed in the trunk of my 2004 E500. The wedge shape of the box allows me to push if flush to the back of the rear seats. The problem is that when I accelerate hard, or take a hard turn, the box will slide around. Is there a way to secure the box so that it won't move around, or tip over? It stays put in normal driving conditions, but who wants to drive it normally?
Here's what it looks like:
Old Jul 2, 2004 | 04:02 AM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Did you try the velcro yet? I am curious, because I am about to have the same problem as you.
-s-
Old Jul 2, 2004 | 09:53 AM
kyee's Avatar
I haven't tried the velcro yet, I was going to, but then I thought about what you said regarding the carpet on the bottom of the trunk not being stapled down. Now I'm not sure if that solution would work.
Old Jul 2, 2004 | 11:21 AM
SuperMoose's Avatar
same problem here in my 88 190d...any suggestions, i dont want a permanent install incase i have to get to my spare tire.
Old Jul 2, 2004 | 11:52 AM
Petie's Avatar
2000 CLK430
the actual box in my trunk install is screwed down. your box has the lips on the sides...look under your trunk liner and make sure nothing important is there, and just screw it down. granted the carpet is a bit coarser in my CLK, but when you take the box out, the carpet is such that you cant even see the holes. velcro doesnt work. the velro part doesnt grip strongly enough to the short carpet and the adhesive side doesnt stick to the carpet either. with two screws, you cant move my box if you wanted to.
Old Jul 2, 2004 | 12:07 PM
kyee's Avatar
Petie - do you have a picture of your sub setup that you could post?
Old Jul 2, 2004 | 12:24 PM
Petie's Avatar
2000 CLK430
i dont, sorry. the sub install is nothing more than a single Alpine Type R 12" Sub in a MDF custom built sealed box, anchored so that its facing through the rear armrest(removed plastic barrier) so that you can see the sub in the cabin. there are two pieces of MDF on each side of the box to more or less seal all of the sound in the cabin instead of in the trunk. then i have a board covered in black carpet serving as a wall in the trunk so that the box and amp cannot be seen. the amp is mounted on the back of the wall. so basically you see a 12" sub through the armrest in the back seat and a black wall from the trunk. nothing fancy or tacky. just giving me the quality sound i wanted without making my car look stupid or making it impractical.
Old Jul 2, 2004 | 04:40 PM
SuperMoose's Avatar
i thought about screwing my box down...but if i ever got a flat...that would be a pain in the *** to pull out.
Old Jul 2, 2004 | 05:02 PM
kyee's Avatar
Yup, I'm going to pass on the screw down solution.
Guess I'll just try the velcro solution first to see if it works. It's a cheap method to try out, and if it doesn't work, then I'm not out that much $$.
Old Jul 2, 2004 | 05:41 PM
FIXEDupW209's Avatar
A bucket on wheels
I don't know how the trunk is setup in the E class but in my C soupe and the CLK, there are rings that come through the carpet of the trunk to tie down items and similar items are placed on the back of the rear seats. I used bungy cords at first (you cna buy them at like home depot) and it worked pretty well but then the carpet would slide around. So what i did was i took the carpet off adn took it to a lumber shop and cut out a piece of 1/2 inch wood in the same shape and placed it in my trunk and bloted the subwoofer box down to it. I simply painted the wood but you can get the wood carpented to match the trunk and it will work great. Now my box doesn't slide around at all.
Old Jul 2, 2004 | 07:28 PM
Petie's Avatar
2000 CLK430
i can get to my spare without taking my box out. definitely a bit more difficult, but honesty unscrewing two screws takes less than a minute.
Petie's Avatar
2000 CLK430
like i said, i tried it, it doesnt work. but if youre going to try, best of luck and if it works, please let us know how you did it.
Old Jul 2, 2004 | 08:08 PM
ronnie0738's Avatar
2003 Nissan 350Z
I just got the exact same sub box combo. I used 2 strips of industrial strength velcro and hasn't moved at all.
Old Jul 3, 2004 | 12:06 AM
Sam 325i's Avatar
Turbo Diesel
you boys just need a bigger sub.
12" boston and 1500 watt kenwood amp in a ported box - thing weighs about a metric ton.
i could flip the car and it wouldn't move.
granted, it's probably killing my gas mileage . . .
Old Jul 3, 2004 | 12:39 PM
Petie's Avatar
2000 CLK430
personally i much prefer the sound quality of a sealed box. not to mention it takes up a whole lot less room.
Old Jul 4, 2004 | 01:14 AM
SuperMoose's Avatar
i came up wtih a solution! i used a eyelet hook? i a look thats liek a screw, put on in the box and the other in the bottom and tied it down. Doesn't move at all now
Old Jul 6, 2004 | 04:00 PM
kyee's Avatar
Could you post some pictures on your setup?
