Bumper Antenna - Single or Dual Band
My 2000 E430 came stock with a bumper antenna for the cellular phone. Hirschmann Part #921761-001; MB Part #A210 820 17 75. Can anyone tell me if this is a single band or dual band antenna?
Originally Posted by miroj
My EPC says nothing. I would have to assume that the vintage of the technology isnt dual band.
Part Number 921700-001 which was replaced with replaced with 92749-001 (a more generic version described as: Antenna - concealed bumper mount, 2 concealed enclosed coils, 3 db gain, 18’ RG-58 cable low loss cable 806-960 mHz) - which was then replaced with the dual band bumper mount antenna 921762-001 (described as: Dual band concealed bumber mount - The Invisible Antenna - concealed bumper mount, 2 concealed enclosed coils, 3 db gain, 18’ RG-58 cable low loss cable dual band, 806-960 mHz - 1850/1990 mHz).
You may have noticed that the part I have 921761-001 is only one digit off the generic dual band part number so I'm hopeful that it is the part number for the MB specific applicaiton of the dual band part (to accept the new dual band linear compensator, new PSE, etc. that I'm installing).
If anyone knows for sure - please let me know.
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
Received 3,238 Likes
If so, you will have a dual-band antenna as the StarTac phones ran on the 1900 mhz band (the 800mhz continued for Teleaid).
Wolfman
I would tend to agree since the linear compensator is a single band compensator - however - the information I've been able to find on Hirschmann antenntas (one of the few sites I could find with coprehensive information in English) shows the following part number for the single band antennal for the w210:
Originally Posted by Wolfman
If I am not mistaken, all 2000 Mercedes build-dates were designed for the StarTac phonekit (unlike some 1999 built 2000 models which were setup for the analog setup; check your build date on the sticker by the driver door).
Wolfman
Wolfman
Build Date was 2000 and options included CDMA and TDMA StarTac phones which I beleive were both at 800Mhz per Wolfgang's "MB Motorola StarTAC® (Single-band, Dual-mode) (discontinued)
800 MHz Analog and CDMA 800 MHz Analog and TDMA".
Super Moderator
I guess there is only a very low probability then that the antenna is dual-band. Good luck...
Wolfman
And the answer is.....
Hirschmann has just verified that the antenna is dual band. The single digit change from their generic dual band bumper antenna signifies a different connector in the OEM MB part from the generic Hirschmann part.
