Starting the car in the morning in cold weather
Do you wait for 30 seconds? 1 min? 2 min? I find that my c250 coupe takes quite long to reach just 60c in this weather. I normally wait 2 mins max and I'd start driving slowly, but the speed is just too slow, and I really don't want to push the RPM higher than 2000 when the engine is still this cold, What's the best method to do this?
Do you wait for 30 seconds? 1 min? 2 min? I find that my c250 coupe takes quite long to get to even 40 c in this weather. I normally wait 2 mins max and I'd start driving slowly, but the speed is just too slow, and I really don't want to push the RPM higher than 2000 when the engine is still this cold, What's the best method to do this?AFAIK, with the diesels they take a long time to properly warm up even in hot climates so I guess you need to wait a little longer for them on typical cold starts
Does anyone have info on those, guess I'll find out soon enough as owning an 'oiler' is all new to me
I do this, the same procedure, in summer and winter. Here in Toronto, the winter temp can go down to -20c.
But I still wouldn't go WOT (Wide Open Throttle) until the engine is fully warmed up. BTW, the temperature gauge is coolant temp, not engine oil temp.
It would also be smart to let the car sit for a few seconds in drive, or not press down the accelerator to increase speed for the first few seconds to let the transmission fluids fully circulate.
I have also heard that it is smart to wait for a car to fully come up to operating temperature before driving away. I have mixed feelings on this. One side of the camp believes that this can cause increased carbon buildup in the engine from increased idle times, while the other side believes that this will give the mechanical components a chance to warm up, preventing brittleness, breaking and improper lubrication of moving components.
If you ask me, waiting for the lifters to settle (RPM's to reach normal levels) is precaution enough. Racked up 60k miles on my 2009 w204 and have not had any issues. And numerous other cars that followed this procedure and have been trouble free.
My 2008 G37 coupe that I had for 24 months off lease did NOT follow this rule of thumb, and was exhibiting rough shifting, rough idle and not running like the other cars that drive like it was the first mile on them, after only 24k miles...
