2011 - C250 4Matic faster then a C300 after ECU Flash
Old Mar 9, 2012 | 10:55 AM
pnikou's Avatar
C250 4Matic 2011
Just got my ECU flashed yesterday thanks to WWW.EUROCHARGED.CA (Give Mike or Barry a call) getting much more pickup and responsive.
Stock my car goes 0-60 in 9.5 second now it's around 8 seconds. (Not bad for only 500 dollar investment) vs $5000 to upgrade to a C300 (now that they have the ECU file the can flash it very quickly)
Also when in manual mode it really holds the revs alot longer and doesn't skip from 1st to 3rd when flooring it.
FYI - The C-Class 250/300/350 share the same engine M272 (Canada)
Difference is with the Bore and Stroke specs:
The E25 is a 2.5 L (2496 cc) version. Bore dimension is 88 mm and stroke is 68.4 mm. Output is 204 PS (201 hp/150 kW) at 6100 rpm with 181 ft·lbf (245 N·m) of torque at 2900-5500 rpm.
The E30 is a 3.0 L (2996 cc) version. Bore is 88 mm and stroke is up to 82 mm. Output is 231 PS (228 hp/170 kW) at 6000 rpm with 221 ft·lbf (300 N·m) of torque at 2500-5000 rpm.
The E35 is a 3.5 L (3498 cc) version. Bore dimension is 92.6 mm and stroke is 86 mm. Output is 272 PS (268 hp/200 kW) at 6000 rpm with 258 ft·lbf (350 N·m) of torque at 3500 rpm
http://en.wikipedia.org/wiki/Mercedes-Benz_M272_engine
Old Mar 9, 2012 | 09:46 PM
qaz393's Avatar
AV6
regular pump gas or premium?
Old Mar 9, 2012 | 10:04 PM
qaz393's Avatar
AV6
wrong section. the v6 4matic are w204 sedan
Old Mar 9, 2012 | 10:10 PM
2012c350's Avatar
2020 C363 S / 2007 SLK55 / 2016 F150 4x4 / 1998 Cobra Convertible
Then they don't share the same engine, but rather same block. The engine is the block/crank/pistons/heads. Displacement is a measure of engine piston travel volume... If the displacement doesn't match and the block isn't identical then its certainly not the same engine.
But if you picked up 1.5seconds for $500 that's a good price.
Old Mar 9, 2012 | 10:12 PM
qaz393's Avatar
AV6
the block might be different. the larger displacement block might have a taller deck height. i know this is true in the case of honda K-series engine.
Old Mar 9, 2012 | 10:48 PM
2012c350's Avatar
Correct. I should've said that the block _may_ be the same. But in either case, the engine certainly isn't.
Old Mar 12, 2012 | 11:57 PM
sales@eurocharged.ca's Avatar
Former Vendor of MBWorld
c63
Glad your liking the tune
Old Mar 13, 2012 | 09:00 AM
qaz393's Avatar
AV6
does it require premium gas after?
Old Mar 13, 2012 | 08:43 PM
Igor1080's Avatar
2013 C204
What are the actual HP/TQ figures? Are the results from dyno?
Old Jun 21, 2012 | 10:44 AM
pnikou's Avatar
C250 4Matic 2011
Stock the car requires Premium Gas
Old Jun 21, 2012 | 10:47 AM
qaz393's Avatar
AV6
no bro. the gas cap says min 91 ron not 91 AKI. 91 ron is equal to 87.
