Coupe and AMG Door pins
Old Apr 11, 2012 | 02:07 PM
Energybiz's Avatar
2012 C 350 Coupe
Did anyone purchase the AMG door pins for their coupe? The doors on my black interior are so dark, I thought the chrome/aluminum pins might help to take away a bit of that starkness.
Old Apr 11, 2012 | 02:51 PM
DinB's Avatar
Honda Civic
I am interested in this also. Did you get them on Ebay?
Old Apr 11, 2012 | 03:39 PM
Energybiz's Avatar
2012 C 350 Coupe
I have not bought them yet. Found them on Ebay also (set of 4, 2 long and 2 short). Just wanted to know others opinions about them and how easy or hard they are to get on.
Old Apr 11, 2012 | 11:22 PM
blackmercs's Avatar
CLC Coupe
Any idea how to remove the stock pin? Try to twist it (clockwise & anti) but its wont barge!!
Old May 7, 2012 | 06:04 AM
paleface's Avatar
C250 Coupe 2011 AMG Package
i already did it. And its nice. my car are Red interior but its look good
this is the picture
and, i buy from ebay (cks performace UK)
I forgot how to remove the original one, i think its anti clockwise. you have to be patient cause the original door pin are long.
Old May 7, 2012 | 11:12 PM
AV1's Avatar
AV1
C204 C250-CDI
Nice !!! ^^^
Are you able to confirm exactly how you got the originals off, I've tried to unscrew mine and they wouldn't budge I didn't want to apply too much pressure in fear of something breaking.
That would be a great help TIA
Old May 7, 2012 | 11:19 PM
paleface's Avatar
Originally Posted by AV1
Nice !!! ^^^
Ok, I will try it in 5min. I will let you know ASAP.
Im back hehhehehe
You have to use pliers and towel so it dont brake. twist it anticlockwise to loosen up.
Old May 8, 2012 | 03:24 AM
AV1's Avatar
AV1
C204 C250-CDI
Im back hehhehehe
I see, thank you paleface
I'm sure other people will find this tip useful too
Old May 8, 2012 | 04:42 AM
paleface's Avatar
no problem,bro
let me know the result ok
just share between c250 users
Old May 8, 2012 | 11:04 PM
AV1's Avatar
AV1
C204 C250-CDI
no problem,bro
Will do
I've already ordered the AMG door pins - just waiting for them to arrive
Old Jun 9, 2012 | 12:00 AM
DL250's Avatar
VW Golf MKVI 118TSI and C250 CDI Coupe (on order)
Any recommendations on eBay sellers?
Old Jun 11, 2012 | 11:17 PM
AV1's Avatar
AV1
C204 C250-CDI
I've recieved and installed mine now and they are a worthwhile addition, looks so much better than stock, even for such a small item
Mine came in a 4 pack including those for the back doors on a sedan.
They are a shorter length, but AFAIK will work just fine on the front doors, so maybe I could pass them on if interested if or when we have a Melb. meet.
These are the ones I purchased DL250
http://www.ebay.com/itm/170726156320...U:3160&vxp=mtr
Old Jun 12, 2012 | 08:16 AM
Twodog's Avatar
2012 350 4M
AMG Door Pins
Crazy prices:
They are 70.00 CDN EACH, yes EACH.
Here in Canada at my MB dealership, M-B Burlington. I think the OEM ones are made of stainless steel, cause they are pretty heavy.
Like a dumb ***, I bought two of them
But they do look good once installed.
Two
Old Jun 12, 2012 | 10:22 AM
Blinks's Avatar
Mercedes Benz C250 CDI coupe
Any pics of them on. This is the first thing i want to replace on my car! I cant stand how cheap and nasty the OEM ones look!
Old Jun 12, 2012 | 10:45 PM
AV1's Avatar
AV1
C204 C250-CDI
They look like the ones in the pics posted by paleface above
You can also refer to the link I posted for pics of the pins on there own, I will put up a pic or 2 of mine sometime over the weekend.
The ones I've got are solid aluminium, brushed finished sides with polished top dome and AMG lettering - your right they do look a whole lot better than OEM and even though they're so small they are easily visible and stand out compared to the plastic black units
Also if you have brushed aluminium trims on your interior they match perfectly and really do make the door interior look heaps better
Old Jun 12, 2012 | 11:20 PM
Blinks's Avatar
are they flush and level to the door trim when they are down?
I've just picked up my car and Its annoying the hell out of me each time i look at them!
Old Jun 13, 2012 | 11:13 PM
AV1's Avatar
AV1
C204 C250-CDI
You can have them finish off at any level you want, including flush to the door trim ring, they are threaded so you simply screw them in as far as you want all the way until flush
I installed mine at the same top finish level as the stock OEM pins which is almost flush to the higher or outer side of the door trim ring and about 2mm or so higher than the lower or inner side of the door trim
Old Jun 14, 2012 | 03:14 AM
DL250's Avatar
Thanks for the info AV1, I have to admit I dont usually notice door pins but since consciously checking them out after reading this thread I can't stand them anymore! The factory ones are probably as ugly as door pins can get.
I have ordered them through my dealer for installation in the coming weeks before delivery and I think it'll add a nice touch.
Old Jun 14, 2012 | 04:03 AM
AV1's Avatar
AV1
C204 C250-CDI
Well done, again for such a small item they do make a big difference
I'm not totally repulsed by the OEM units LOL, IMO they look ok it's just that the metal AMG units look a whole lot better and make a nice match to all the other similar finished bits in the interior
Old Jun 17, 2012 | 06:06 PM
andrew e coupe's Avatar
2017 E400 Coupe & 2018 GLC43
I would a like a set in solid matte black metal/alum to retain the factory look but in better than oem plastic materials.
Old Jun 17, 2012 | 11:04 PM
AV1's Avatar
AV1
C204 C250-CDI
You could probably get them (the AMG metal pins) painted in a tinted clear coat and achieve that finish, would look great like the tinted finishes you get on brushed alloy wheels
Old Jun 27, 2012 | 08:51 AM
Blinks's Avatar
Thinking about ordering these. How long did it take for delivery?
Old Jun 27, 2012 | 07:39 PM
dol4er's Avatar
C204
They look much better than the black stock pins.
Does anyone know the Mercedes genuine part number of these AMG pins?
Old Jun 27, 2012 | 11:18 PM
AV1's Avatar
AV1
C204 C250-CDI
Was less than 1 working week, 4 days if I remember correctly
If you do get them just beware that when installing make sure you start off the thread properly or with any miss-alignment they'll become awefully hard to screw in, they should screw in easily by hand without having to use plyers
