-COUPE DROP-
2012 Mercedes c250
-COUPE DROP-
Hey guys!! if any of you dropped your coupe. if you guys could please place the Brand of the spring/coilover and the drop (inches), im in the market of getting my car lowered and wanted to compare the diff brands and drop. and if anyone could shoot me an "about" quote of how much it would cost to get the spring/coilover installed? Much Appreciation!
i have been looking for simply lowering springs and nothing is out yet for our cars application (C250 coupe)...
(tentative arrival time 9/1/12 per eibach and h&r).
eibach pro kit: #10-25-019-03-22
h&r sport kit: #52794-2
i also want to buy 19" wheels but there's no point until the cars lowered.
Customer of Alpha Motorsports, they ship worldwide and have the best prices.
Sales@alphamotorsports.ca
H&r springs and VMR wheels:
2012 Mercedes c250
2012 Mercedes c250
alright i thought you were trying to send me the link to the site, i was expecting prices and pics lol. ill get in contact with them thanks!
I just got mine dropped on Friday. Approx 1 to 1.2 inch drop with H&R. Ordered it 2-4 months ago, but never got around to installing.
Tirerack should have the correct part number. You should order it from them. Usually the cheapest price online and shipping is extremely reasonable for the size of the package.
tried to order via the tire rack and they are now on backorder.
new to the c350 coupe had e92 335xi for a couple years and knew that if you had put different spring instead of coilovers that you would have severe damage over the course of time to the stock suspersion. Is this the same for the c350 coupe or do they have a different type due to the agility suspension control. Would save alot of money if someone could clarify for me!
i plan on installing the eibach pro-kit once availabe without replacing the shocks... there should be no issues with this set up on the mb.
~ finally my wait is over ... they have arrived via fedex directly from germany today... these are no where to be found in the USA (not released as of yet).
to be installed a week from today... more pics to follow.
well i had the eibach pro-kit springs installed today...
i love the drop on the front but the rear seems to have very little change? do you think it will settle? (specs were to be 1.1" front & 1.0" rear) ... thoughts?
Enzo, my Benzo
Personally, Andrew yours looks better than the black one. Having a forward raking stance with lower in front than back looks a billion times better than the other way around like the black car. Last resort you could cut a coil or 2 on the back springs...these aren't race cars so it doesn't really matter much.
2012 C250 Coupe
No whole behind any badging on our cars besides for the rear trunk mercedes emblem (three tiny holes)... just use some strong fishing line or something thin and a hairdryer. The double sided glue they use is STRONG!
As far as the drop goes, give it a couple days. The springs will most likely settle a little bit over the next 3-5 days, lowering it a little bit more. If not, then you can always cut a little bit more of the springs off, or use thinner pads as suggested.
i had a 9mm pad installed on the rear today. i was told the w204 cars should have a 13mm pad in the rear but the coupe has a 17mm pad (4 bumps noted in pic)... therefore i switched to a 9mm pad for the correct spacing (8mm difference). it sits perfect now.
https://mbworld.org/forums/c-class-c...0-bbs-h-r.html
