Side Markers
Old Aug 18, 2012 | 09:51 PM
davidwhelan3's Avatar
2012 C250 Coupe w/ AMG Package
Side Markers
Is there anyone who knows where to buy painted side markers and/or has any suggestions for tinting them black? I took them off and tried wrapping them in tail light tint film but it was too thick. I don't really want to plastidip them because it doesn't match the color of the car.
Old Aug 19, 2012 | 06:24 AM
andrew e coupe's Avatar
2017 E400 Coupe & 2018 GLC43
~ i simply had mine professionally painted...
Old Aug 19, 2012 | 10:33 AM
Yeah I saw that in another post about side markers, I'm making that my last resort although it looks pretty good, I'd rather keep the oem ones incase I sell the car
Old Aug 19, 2012 | 07:10 PM
Originally Posted by davidwhelan3
I'd rather keep the oem ones incase I sell the car.
~ i purchased an extra set from the dealer... and then had those painted ... retaining the stock ones...
here are part numbers:
A 204 906 74 01
A 204 906 73 01
Old Aug 19, 2012 | 07:39 PM
A 204 906 74 01
A 204 906 73 01
Thanks! Do you remember how much it cost after everything?
Old Aug 20, 2012 | 07:43 AM
the lenses are about $50...
and the painting was around $125 (body shop pia to breakout the paint gun for such a small item).
so around $175.
Old Aug 24, 2012 | 12:05 PM
DucatiCLS550's Avatar
ON SUSPENSION
11'W212 E550-11'W219 550 -12'X204 4MATIC- 12'W204 M271 1.8T
Looks Great ! awesome
Old Aug 26, 2012 | 02:06 PM
Normandie4life's Avatar
Black C300
instead of trying to wrap it with tint film you should try vinyl its much easy to work with
Old Aug 26, 2012 | 02:20 PM
Yeah I have worked with vinyl in the past, I recently wrapped my friends BMW steering wheel trim in carbon finer vinyl, and that's the only type i have right now, I have to order some black vinyl, thanks for the tip!
Old Aug 27, 2012 | 11:00 AM
Ubiquitous5's Avatar
C350
Great mod. Definitely worth $175.
Old Aug 27, 2012 | 07:21 PM
jctevere's Avatar
2012 C250 Coupe
Additionally, you could buy osme white plastidip and spray over them, then just peel it off when you want to sell the car. One can could easily cover both sidemarkers, and more, and its only $5-6 per can... The white plastidip isn't a perfect match, but its a pretty good match to our paint color. And you can even use glossifier to make it non-matte.
Old Aug 28, 2012 | 01:09 AM
STANimal's Avatar
C250 Coupe
Are the side markers easy to replace? Some jerk hit the bumper a month into my ownership of a C250 coupe and didn't leave me any contact info so I need to replace the side marker =(
Old Aug 28, 2012 | 05:38 PM
jctevere's Avatar
2012 C250 Coupe
Very easy to replace... At least on my prior 2009 C300. You simply access it form the wheel well. Remove the black plastic wheel well liner with three plastic clips. Then there is a simple torx screw to remove from the back of the sidemarker, and two more plastic clips and it comes right out. I don't suspect that the 2012 re-design changed the install/uninstall process much...
Old Aug 30, 2012 | 02:33 PM
Flyer155's Avatar
2012 Mercedes C250 Coupe (C204)
Another option you have is to get a set of new painted markers from Evosport.com CA. Just tell them the color code of your car and they will provide you with new OEM painted markers.
I ordered a set of Pre-Painted Bumper Reflectors for my C250 Coupe in Magnetite Black Metallic (colour code 183) and paid $149 for both plus $22 for shipping.
Old Aug 30, 2012 | 03:25 PM
xxGenericSNxx's Avatar
99 ML430, 01 CLK55, 07 R63, 15 E63 Wagon
I had my CLK ones painted at the local body shop. Cost was around $50 for me. Make sure you have them sand off the letters first so that it's nice and smooth.
What did you guys do about the light? I left mine in there and you can faintly see the light behind the paint when it's on. It looks kind of odd but I don't want to mess with the light in fear of that stupid error on the dash.
Old Jan 5, 2013 | 08:13 PM
MrH's Avatar
MrH
2010 E550 Coupe
Evosport recommended using a black sharpie on the bulb. No light, no error codes.
Old Jan 6, 2013 | 09:46 PM
InTheBenz0's Avatar
GLC 63 S AMG / Corvette C8 / Jaguar SVR
A black sharpy all over the bulb? Did they tell you that or publicly post that up
Old Jan 16, 2013 | 01:12 AM
angeloxnet's Avatar
15 Mercedes C400, 12 Mercedes C250 coupe
what about using a canbus LED's and break them by snapping the actual LED.
yes it sounds crazy but wouldnt the resistor not cause an error out?
Old Jan 16, 2013 | 05:02 PM
sheizfreshhh's Avatar
2013 c250 coupe
I actually had mine removed and wrapped in tint film. During the day it looks really nice, but at night when the light comes on you can still somewhat see the orange.
Old Jan 16, 2013 | 05:27 PM
BlackjackM's Avatar
2018 E300 Lux, 2006 Corvette Z51, 2015 Mercedes ML350 (wife's)
I tried Lamin-X on mine, didn't like it. The film is great stuff that I've used many times in the past but the curvature of the lens makes it difficult to wrap. I then tried spray tint and wasn't happy with that either.
I just can't believe no one has made smoked ones yet.
Old Jan 16, 2013 | 05:30 PM
2013 c250 coupe
I used the tint film from Oracle. It requires a little stretching around the edges so that it doesnt lift.
Old Jan 16, 2013 | 09:39 PM
100degrees's Avatar
C250 Cpe, E90 M3
Are the sidemarkers on the coupe different from the sedan?
