c250/350 Bi-Xenon headlights available on ebay: Retrofit???
Old Sep 4, 2012 | 12:57 PM
DameMD's Avatar
X3 M40i
I was doing some ebay searching and came across a couple pair of the 2012 c Coupe projector headlight housings without the Bi-xenons. I have the standard halgoens with added HID 4500k kit (lowered to ground level) and resistors to stop the error codes. My question is... Could one purchase these lights and just switch out the wiring like add a HID kit to the projectors lenses and splice the city wires to get the "C" LED light to work, and same for the amber turn signal?
This would be a great option to do since this is just the housing. No need to wire up everything to the harness if you could splice into the wiring.
http://www.ebay.com/itm/2012-MERCEDE...sories&vxp=mtr
Old Sep 6, 2012 | 07:16 PM
AV1's Avatar
AV1
C204 C250-CDI
The intelligent light system headlights option are most definitely IMHO a must have compared to the plain featureless headlights installed as standard, I'm glad I've got them on mine
The only concern I'd have with the above is installing them and not have everything working because of other missing bits if that ends up being the case
There are many many features that those headlights offer compared to the standard ones.
I'd consult your dealer techie and see if your C Coupe has wiring and programming already there to accept these to make full use of them and get proper OEM Bi Xenon bulbs installed, rather than just swapping them out as is minus all the features and fitting an aftermarket Xenon HID kit, for a start your hi beam will not work in that case as it's the projector itself that swings up and down on these for high beam/low beam.
Old Sep 16, 2012 | 10:23 AM
kasimmmmm's Avatar
C250c
if you buy the wiring harness, they will work.
I was looking at the exact same ebay listing... the other side headlight is also available in a different listing but is missing the ballast.
i intend on doing a retrofit this winter.
Old Sep 19, 2012 | 09:44 AM
achance's Avatar
2017 E300 Sport
kasimmm, do you have the part number for the wiring harness? I'm thinking about it also.
Thanks,
Old Sep 20, 2012 | 02:20 PM
DameMD's Avatar
X3 M40i
Kasim, let me know when you begin the project. I am really thinking about doing a retrofit in the next month or two.
Old Sep 23, 2012 | 12:03 PM
hellasmania219's Avatar
2009 C300, 2012 GLK350, 2012 C350C
anyone ever get a hold of this person?
he did the bi-xenon upgrade...
http://ameblo.jp/prostuff/theme-10012057912.html
http://www.prostuff-net.com/w204/w204.html
Old Feb 4, 2013 | 01:28 AM
jayparry's Avatar
Bmw 135i
You guys have any luck with the xenon upgrade?
Old Feb 4, 2013 | 10:01 PM
Hzkasbarian's Avatar
2012 Mercedes c250
I agree, this is one thing i want to know how to do.
Old Feb 5, 2013 | 04:56 PM
DameMD's Avatar
X3 M40i
I was going to however the headlight housings are still too expensive. I have been trying to locate the c coupe/sedan projector housing at junk/auto yards and stuff and not available. The ones that keep popping up on ebay are over $700 for one side.
Old Feb 5, 2013 | 09:11 PM
2012 Mercedes c250
yup and those are the only ones i could find too
Old Apr 27, 2014 | 01:42 PM
crazymofokah's Avatar
2014 C250
These aren't too bad, and the price went down a lot!
http://m.ebay.com/itm/171312366465?fits=Model%3AC250
Old Apr 27, 2014 | 04:41 PM
capt_paul's Avatar
2013 C350 Coupe, 2005 C230K Kleemann Sedan, 2013 GLK350 4matic
I am actually doing a retrofit from standard halogen lights to bixenon lights. In addition, I am added the headlamp washers.
You need headlamp assemblies, light control unit, wire harnesses, level sensors for the front and rear, and the multi-function camera. If adding the headlamp washers, you will need a new front bumper cover and the flaps. I need to replace the windshield as well, because I did not have the multi-function camera already.
All the parts are coming off a car that only had 350 km on it, so they are still in excellent condition. The cost of the parts including the windshield and the front bumper come out to just under $5000, so not a cheap project by any means.
Old Apr 27, 2014 | 05:14 PM
amgboyw204's Avatar
c250 coupe .2012 e550 coupe
A friend of mine did the samething but he got the used oem headlights from ebay They are as good as new an cheaper !it cost him $1800 for the upgrade
