C204 Silver Grille to Gloss Black - Plastidipped
So I tested the pieces with Plastidip:
1. Black Plastidip (matte finish) x 4 coats
2. Glossifier (to convert to gloss black) x 3 coats
I've attached some before & after photos.
Let me know what you think.
My Conclusion:
To be quite honest, if you are looking for a PERFECT finish, then Plastidip is NOT the answer.
However, it does serve as a good testing ground because it is completely removable and can be peeled off without any issues.
Having said all this, I will probably remove the plastidip soon and just get the grille sprayed in gloss black.
Hope this thread gives people an idea of what a gloss black grille would look like on their cars. It is very aggressive looking and in my opinion, much better than the stock silver look.
I had plastidip sitting around from other projects, so I gave it a test to see if I liked it before getting it sprayed. At $25 a can, it's inexpensive.
My Conclusion:
Probably easier to remove the grille next time...might give you a better result with the grille lying flat on the ground (during drying period)?
See how you go
You don't want to know the RRP on the car. Double US prices
And yeah, you're right.....definitely not for OCD types.
I would've done vinyl, but I think it' would be really hard with the silver part around the entire 3 point start part...Easier just to spray.
I suppose any black high lights to trims are a matter of taste and a case of each to their own
Personally I still prefer the silver colour on the grille for my diamond white Coupe, I'm going to get it painted up in gloss silver exactly the same as on the grilles of the E Class that way it'll both look better and be easier to clean
.. Great tips!
